AP135 POWEROFF after eth0 disconnected from other side.
  • 1.  AP135 POWEROFF after eth0 disconnected from other side.
    Posted Nov 05, 2014 12:14 PM
    1. our customer test IAP 135,they connected IAP 135 ETH0 TO A PC directly.When ETH0 port is not connected (for example, the PC connected to it is powered off), after some time, the AP will power off. Can we wake it up again through ETH0 (boot up the PC connected to it)?   and is this a wellknow issue?
  • 2.  RE: AP135 POWEROFF after eth0 disconnected from other side.
    Posted Nov 05, 2014 04:02 PM
    You can uncheck the "Disable this SSID on uplink failure"-checkbox on the SSID.
    Also check: http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Site-Survey-with-IAP-Manual/td-p/57274
