AP135 shuts down eth1 due to insufficient POE voltage [power profile 2]
  • 1.  AP135 shuts down eth1 due to insufficient POE voltage [power profile 2]
    Posted May 09, 2013 11:31 AM
    AP135 is plugged into Cisco 3560x switch and lldp is enabled as well. But it shuts down eth1 port due to insufficient power.
    Any ideas?
  • 2.  RE: AP135 shuts down eth1 due to insufficient POE voltage [power profile 2]
    Posted May 09, 2013 01:22 PM
    You need 802.11at in order to get power on e1 and the 3560 supports 802.11af instead.
  • 3.  RE: AP135 shuts down eth1 due to insufficient POE voltage [power profile 2]
    Posted May 09, 2013 01:32 PM
    What code are you running? This behavior has been changing a bit in recent releases.
    Prior to 6.2, only layer 1 negotiation for 802.3at POE was supported. With 6.2, LLDP can be used to identify an 802.3at source.
    /Onno Harms, Aruba
  • 4.  RE: AP135 shuts down eth1 due to insufficient POE voltage [power profile 2]
    Posted May 09, 2013 01:42 PM
    @vfabian - 3560X supports POE+
    The code is 6.1.3.8. This means I need to use a POE injector for the AP?
  • 5.  RE: AP135 shuts down eth1 due to insufficient POE voltage [power profile 2]
    Posted May 09, 2013 01:51 PM
    If you need the second ethernet port, you should either use an 802.3at midspan, or upgrade to 6.2.
  • 6.  RE: AP135 shuts down eth1 due to insufficient POE voltage [power profile 2]
    Posted May 10, 2013 03:23 PM
    I also had to upgrade the IOS image on Cisco 3560X to get it working. (12.2 => 15.0)
  • 7.  RE: AP135 shuts down eth1 due to insufficient POE voltage [power profile 2]
    Posted May 09, 2013 01:54 PM
    missed the "x"
