AP175 Antennas
  • 1.  AP175 Antennas
    Posted Aug 23, 2013 04:03 AM
    i think AP175 supports 4 external antennas as mentioned @ datasheet
    so if i need coverage + Mesh i will get :
    1*  ANT-2x2-2005
    1*  ANT-2x2-5005
    For each AP-175 , right ?
  • 2.  RE: AP175 Antennas
    Posted Aug 23, 2013 07:17 AM
    Yep. It 1 part number for two ant ports of 2.4 and 1 part number for the two ant port of 5.0.
    *it's for direct mount on the acceesspoint itself*
    But u should consider other parts as lighting arresting parts (if deployed outdoor) + POE solution (outdoor solution that will provide enough and needed outdoor protection to the infrastructure that going to the accesspoints.
    More relevant info regarding all ant types u may find here:
    http://www.arubanetworks.com/pdf/products/matrix-antennas.pdf
    http://www.arubanetworks.com/products/access-points/indoor-and-outdoor-antennas/
    :catlol: have a lovley day
    Me
