AP175P - Unable to Purge
  • 1.  AP175P - Unable to Purge
    Posted Jul 19, 2012 02:33 AM
    i was configuring my AP175 in a mesh point mode but as soon as i was done configuring it, the AP stopped working and was rebooting on its own after a minute or so.
    So, i decided to purge all the settings using USB/cable console, but AP got stuck whenever i was trying to put in apboot mode.
    Right now the AP seems useless to me not able to do nething with it.
    Any help in this matter?
    Regards
    Muhammad Muddassir Khan
  • 2.  RE: AP175P - Unable to Purge
    Posted Jul 19, 2012 05:53 AM
    n i cant listen to the AP through controller.
    i need urgent help in this matter
  • 3.  RE: AP175P - Unable to Purge
    Posted Jul 19, 2012 06:18 AM
    Were you trying to configure it as a mesh point or mesh portal?
  • 4.  RE: AP175P - Unable to Purge
    Posted Jul 19, 2012 07:25 AM
    As i mentioned earlier i was configuring it as mesh point
  • 5.  RE: AP175P - Unable to Purge
    Posted Jul 19, 2012 07:29 AM
    What steps did you use to configure the mesh profiles?  The user guide instructions are fairly straightforward.
  • 6.  RE: AP175P - Unable to Purge
    Posted Jul 19, 2012 07:34 AM
    I knw they are. I have two 175aps i ve configured one of them as portal and it works fine. I wanted to configure the 2nd one as a mesh point after configuring its dead. I have configured it before so i do knw the steps. But now nothngs works cant even purge the ap
  • 7.  RE: AP175P - Unable to Purge
    Posted Jul 19, 2012 07:43 AM
    When you say can't purge the ap, can you get a console connection to show output, or no?
  • 8.  RE: AP175P - Unable to Purge
    Posted Jul 19, 2012 07:52 AM
    Yea i do get the output through console. At the point wen ap is in the reboot state n it asks u to press enter to stop autoboot, i hit enter, thn ap is in the "apboot>" mode after tht im unable to do anything, cant enter the purge command or for tht matter any other command.
  • 9.  RE: AP175P - Unable to Purge
    Posted Jul 19, 2012 09:12 AM
     Are you sure you have the baud, flow control  (none) correct on your terminal?
  • 10.  RE: AP175P - Unable to Purge
    Posted Jul 20, 2012 03:50 AM
    Thank you man it worked, flow control was not selected to none.
