AP1X IAP automatic provisioning information
  • 1.  AP1X IAP automatic provisioning information
    Posted Aug 28, 2020 04:56 AM
    Hi all, we want to use AP1X with clearpass to do 802.1x on the switch port the ap is connected to. I can see you have to configure this per ap. I'm looking for some experience about automating this process, so we don't have to configure all ap's separate.
    So here are the questions:
    - Is there a way to provision or configure all IAP's at once with the AP1X for EAP-PEAP and/or EAP-TLS.
    - I'm wondering if there is a procedure for local configuration and configuration with central.
    Hoping someone is willing to share some automation process for this.
  • 2.  RE: AP1X IAP automatic provisioning information
    Posted Aug 30, 2020 07:16 PM
    I think you should be able to do it using template with Airwave. The templates have per AP setting which do this job for you.
  • 3.  RE: AP1X IAP automatic provisioning information
    Posted Sep 24, 2020 05:02 AM
    We are going to use central for this. Would be nice to send the config to all aps at once...
  • 4.  RE: AP1X IAP automatic provisioning information
    Posted Dec 16, 2020 03:37 PM
    Anyone can share how to automate this? It seems there is no api for this setting....
    James -
