AP203H AND TRUNK PORT CONFIG -OFFICE CONNECT SWITCH
  • 1.  AP203H AND TRUNK PORT CONFIG -OFFICE CONNECT SWITCH
    Posted Jul 18, 2018 01:03 AM
    We are working on a project with AP 203H with the controller-based solution and Office connect switches.
    Customer wants to connect IP TV on wired ports of 203H
    1.what will be the configuration required on Switch and controller ?
    2. Is trunk config required on OC switch ?
  • 2.  RE: AP203H AND TRUNK PORT CONFIG -OFFICE CONNECT SWITCH
    Posted Jul 19, 2018 04:51 AM
    Please work with you Aruba partner or Aruba SE.
    If you tunnel the wired and wireless networks to the controller, you don't need tagged VLANs on the AP uplink.
    For the configuration to get IP TV on one of the wired ports, you will need to connect the IP TV VLAN to the controller, create roles and wired profiles, and assign those to the ethernet port of the AP (or AP-group).
    Your Aruba partner or Aruba SE can help you to get this configured.
