AP205 won't provision
  • 1.  AP205 won't provision
    Posted Nov 04, 2016 11:12 AM
    Hi All
    First time poster, so be gentle please...
    We've got an AP205 that just won't configure - it can't be seen on the controller (managed by a 3rd party IT provider) though other AP205s we have work without any problems.
    I've copied the output from the putty session via the serial cable - can anybody see anything glaringly obvious? My gut instinct is that the flash memory has corrupted but I'd be grateful for any guidance.
    Best wishes
    Mike.
    apboot> boot
    bootcmd environment variable not found
    apboot> purgeenv
    Erasing flash...apboot> save
    Saving Environment to Flash...
    Erasing flash...apboot> boot
    Checking image @ 0x1e100000
    Invalid image format version: 0xea14f09f
    Checking image @ 0x1ef00000
    DHCP broadcast 1
    DHCP IP address: 192.168.65.235
    DHCP subnet mask: 255.255.255.248
    DHCP def gateway: 192.168.65.233
    DHCP DNS server: 0.0.0.0
    DHCP DNS domain:
    Controller address: 10.0.6.131
    Using eth0 device
    TFTP from server 10.0.6.131; our IP address is 192.168.65.235; sending through g        ateway 192.168.65.233
    Filename 'armv7ns.ari'.
    Load address: 0x4000000
    Loading: #################################################################
    done
    Bytes transferred = 6506804 (634934 hex)
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    Automatic boot of image at addr 0x04000000 ...
    Uncompressing... done
    [    0.000000]
    [    0.000000] Aruba Networks
    [    0.000000] ArubaOS Version 6.4.2.5 (build 48774 / label #48774)
    [    0.000000] Built by p4build@formentera.arubanetworks.com on 2015-02-24 at 20:35:48 PST (gcc version 4.7.2)
    [    0.000000]
    [    0.000000] Flash variant: variant0
    [    0.000000] Memory: 128MB = 128MB total
    [    0.000000] Memory: 121124k/121124k available, 9948k reserved, 0K highmem
    [    0.052000] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
    [    3.266000] PMU: registered new PMU device of type 0
    [    3.772000] pci 0001:00:00.0: BAR 8: assigned [mem 0x08000000-0x080fffff]
    [    3.774000] pci 0001:01:00.0: BAR 0: assigned [mem 0x08000000-0x08007fff 64bit]
    [    3.776000] pci 0001:01:00.0: BAR 0: set to [mem 0x08000000-0x08007fff 64bit] (PCI address [0x8000000-0x8007fff]
    [    4.278000] pci 0002:00:00.0: BAR 8: assigned [mem 0x40000000-0x400fffff]
    [    4.280000] pci 0002:02:00.0: BAR 0: assigned [mem 0x40000000-0x40007fff 64bit]
    [    4.282000] pci 0002:02:00.0: BAR 0: set to [mem 0x40000000-0x40007fff 64bit] (PCI address [0x40000000-0x40007fff]
    [    4.628000] i2c-springbank: using remapped base c9d1c060
    [    4.630000] mpcore_wdt mpcore_wdt: enabling watchdog.
    [    4.634000] qspi_iproc qspi_iproc.1: 1-lane output, 3-byte address
    [    4.638000] m25p80 spi1.0: mx25l25635e (32768 Kbytes)
    [    4.640000] Creating 1 MTD partitions on "spi1.0":
    [    4.642000] 0x000000000000-0x000002000000 : "qspi"
    [    4.646000]
    [    4.646000] Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    [    4.650000] Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    [    4.664000] Starting Kernel DES KAT ...Completed Kernel DES KAT
    [    4.668000] Starting Kernel AES KAT ...Completed Kernel AES KAT
    [    4.670000]
    Domain Name: arubanetworks.com
    cat: /tmp/boardname: No such file or directory
    [: Ardmore: unknown operand
    No panic info available
    [: Talisker: unknown operand
    [    6.326000] AP xml model 81, num_radios 2 (jiffies 3163)
    [    6.328000] init_asap_mod: installation:0
    [    6.330000] radio 0: band 1 ant 0 max_ssid 16
    [    6.332000] radio 1: band 0 ant 0 max_ssid 16
    Starting watchdog process...
    Getting an IP address...
    [    8.724000] ADDRCONF(NETDEV_UP): bond0: link is not ready
    [   10.726000] bond0: link up (1000FD)
    [   10.730000] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    192.168.65.235 255.255.255.248 192.168.65.233
    Running ADP...Done. Master is 10.0.6.131
    [   13.356000] wifi0: AP type AP-205, radio 0, max_bssids 16
    [   13.400000] wifi1: AP type AP-205, radio 1, max_bssids 16
    [: closing paren expected
    AP rebooted Fri Nov 4 14:32:44 GMT 2016; SAPD: Reboot after image upgrade failed: 256
    shutting down watchdog process (nanny will restart it)...
            <<<<<       Welcome to the Access Point     >>>>>
    The system is going down NOW !!
    Sending SIGTERM to all processes.
    Please stand by while rebooting the system.
    [   59.488000] Restarting system.
    APBoot 1.5.3.14 (build 45815)
    Built: 2014-09-05 at 11:23:04
    Model: AP-20x
    CPU:   BCM53011/15, revision A0
    I2C:   ready
    SKU:   2
    OTP:   0xeca01028
    Clock:
           CPU:  800 MHz
           DDR:  533 MHz
           AXI:  400 MHz
           APB:  200 MHz
           PER:  400 MHz
    DRAM:  128 MB
    POST1: memory passed
    SF:    Detected MX25L25635E with page size  4 kB, total 32 MB
    Flash: 32 MB
    PCIe0: RC, link up
           dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
           00  00  14e4  4360 00002   03 08000004 00000000 00000000 00000000
    PCIe1: RC, link up
           00  00  14e4  4360 00002   03 40000004 00000000 00000000 00000000
    Power: DC
    ## Error: environment overflow, "stdin" deleted
    ## Error: environment overflow, "stdout" deleted
    ## Error: environment overflow, "stderr" deleted
    Net:   ERROR: could not get env ethaddr
    ## Error: environment overflow, "ethact" deleted
    eth0## Error: environment overflow, "ethact" deleted
    Radio: bcm43460#0, bcm43460#1
    apboot> Printenv
  • 2.  RE: AP205 won't provision
    Posted Nov 04, 2016 12:48 PM
    You should open a tac case.  It could be a hardware issue...
  • 3.  RE: AP205 won't provision
    Posted Nov 04, 2016 02:01 PM
    I agree with CJ, Several years ago I had a very similar issues with two AP105's. Turns out there was bad hardware involved and TAC set me up with warranty replacements.
