We really would like to have a wall-mount bracket for the AP205H that allows it to be flush to the wall and powered from the e0/pt port. which means, we need a wall-mount bracket that is thick enough to allow the space of the jumper ether cable from the back and have the AP mounted flush to the wall, wihout using a third party wiremold adapter. (such as panduit and others).
In the box of the AP205H is the AP, and the singlegang box adapter (that is not thick enough to allow the ethernet jumper cable in the back) to be mounted flush to the wall.
in the AP205H-MNTR comes the desk mount, which has a curvy back, cannot be mounted to the wall and the Ethernet Jumper cable.
#AP205H
