AP205H Wired Configuration
  • 1.  AP205H Wired Configuration
    Posted Jul 24, 2018 07:25 AM
    Hello all,
    Let me start off with I am new her eand mostly a server / storage guy.
    I aquires a couple of APs (205 & 205H) attending events for work that I am attempting to get up and running in my home network.
    I have have been mostly successful except for 1 issue I cannot find a resolution for.
    on the AP205H, I am using E2 to connect to a netgear router/AP that is part of my security system. the router does not work as a true AP as it works int he z-wave bands and only security devices use it.
    It uses an uplink to contact the central server and get updates.
    I have tried using the default wired configuration as well as configuring my own "home" network.
    I have the 205H configured to use network based DHCP and only the default VLAN (assuming it is VLAN 1).
    no matter how I configure this, the security router does not connect to the internet and ends up with a 172.xxx.xxx.xxx address, which appears to be the default from the 205H DHCP.
    Can anyone tell me what I may be missing in the configurationt o get the port to basically "pass through" the 205H ?
    thanks !
  • 2.  RE: AP205H Wired Configuration
  • 3.  RE: AP205H Wired Configuration
    Posted Jul 24, 2018 08:56 AM
    Thanks for this, it confirms that I did configure the wired network correctly (although slightly different as I am on 6.5.x.x).
    It appears that having POE turned on was causing the issue. Once that was turned off, everything started working.
