last person joined: 2 hours ago
AP207 Updates
  • 1.  AP207 Updates
    Posted Aug 10, 2018 03:38 AM
    Hi. I'm new at the community and I would need some help.
    In my company we have almost 40 AP207 access points for wi-fi function. I would like to update the firmware for all the access points and as you can see on the attached image I can do it with the auto function of Instant.
    The question is what is this upgrade doing? Is it upgrading InstantOS on every access point? Is it upgrading Instant?
    Thanks.
  • 2.  RE: AP207 Updates
    MVP EXPERT
    Posted Aug 10, 2018 03:40 AM
    The upgrade will be downloaded to the master AP automatically then distributed and upgrade the remaining AP's in turn automatically.
  • 3.  RE: AP207 Updates
    Posted Aug 10, 2018 03:45 AM
    Thank you for your answer.
    This upgrade is for InstantOS?
    Can I select only some of the Access Points to test the upgrade.
    Because if anything go wrong I will have to reset 40 APs!
  • 4.  RE: AP207 Updates
    MVP EXPERT
    Posted Aug 10, 2018 03:48 AM
    Yes, it will upgrade the InstantOS firmware running on the IAP's. In order to segregate a single IAP to test with, you will need to convert it to a standalone IAP.
    https://www.arubanetworks.com/techdocs/Instant_40_Mobile/Advanced/Content/UG_files/IAP_management/ConvertingIAPtoStandalone.htm
  • 5.  RE: AP207 Updates
    Posted Aug 10, 2018 03:50 AM
    Is there any possibility to have a crashed update?
    Does it happen often?
  • 6.  RE: AP207 Updates
    MVP EXPERT
    Posted Aug 10, 2018 03:52 AM
    A crashed update as in a failed update? I've never had any issues during my experience of updating IAP's, they are generally pretty solid :D
  • 7.  RE: AP207 Updates
    Posted Aug 10, 2018 04:38 AM
    So I managed to set an AP as standalone, updated the firmware and now I want to turn it back to the previous Virtual controller.
    Which option should I choose?(see the attachment)
  • 8.  RE: AP207 Updates
    MVP EXPERT
    Posted Aug 10, 2018 04:54 AM
    Easiest way would be to reset it and let it join the existing cluster. It will automatically downgrade its firmware and configuration and join the cluster.
