AP225 aggregated ports - configuration required?
  • 1.  AP225 aggregated ports - configuration required?
    Posted Apr 25, 2016 07:22 AM
    I have a number of AP225 APs being installed without a controller.
    I have LACP trunk ports setup on HP 2950 POE+ switches however once I connect both Ethernet ports on the AP I lose IP connectivity - I am unable to see where I apply any configuration to configure aggregated ports on the AP for throughput.
    From what I have read I need to add a LMS IP and GRE STRIPING however this seems to be directed towards a controller?
    Can someone advise?
  • 2.  RE: AP225 aggregated ports - configuration required?
    Posted Apr 25, 2016 07:24 AM
    Did you create a trunk on the switch with LACP enabled?
  • 3.  RE: AP225 aggregated ports - configuration required?
    Posted Apr 25, 2016 07:26 AM
    Yes - LACP trunk created on the switch
