AP225 Compatibility with 3000 Series Controllers
  • 1.  AP225 Compatibility with 3000 Series Controllers
    Posted Jul 21, 2013 02:36 AM
    Can anyone please confirm if AP225/224 is compatible with controllers other than 7200 series? By compatible i mean with all its features and functionalities e.g speed upto 1.3 Gbps etc?
    Speed is one feature, i want to know about all the features of AP225/224 that may or may not be available when used with controllers other that 7200 series.
    Thank you.
  • 2.  RE: AP225 Compatibility with 3000 Series Controllers
    Posted Jul 21, 2013 07:58 AM
    Yes it is compatible .
    Note: that if you have a 3200 controller it requires a memory upgrade . In order for 225/224 to work the controller needs AOS 6.3
    Thank you
    Vic
    Sent from my iPhone
    "Keep Smiling"
  • 3.  RE: AP225 Compatibility with 3000 Series Controllers
    Posted Jul 21, 2013 08:28 AM
    Yes i know that AP225/224 can be terminated on, say,  MC3400 but i wanted to know that whether it will continue to provide all the features that come with 11ac as well?
  • 4.  RE: AP225 Compatibility with 3000 Series Controllers
    Posted Jul 21, 2013 09:44 AM
    As long you have 6.3 the AC features will be supported
    Thank you
    Vic
    Sent from my iPhone
