AP225 GRE Stripping
  • 1.  AP225 GRE Stripping
    Posted Apr 22, 2014 12:43 PM
    Can some one explain to me how GRE stripping work when there are two Controllers? Does each controller need to have an ip assign and ip+1? Also, does it need to be on the same subnet and routable?
    Thnx.
    #AP225
  • 2.  RE: AP225 GRE Stripping
    Posted Apr 22, 2014 12:58 PM
    This will be the straight forward config.
     In the WebUI go to Configuration > Controller > Controller IP Details. Set the appropriate mgmt IP.
    Set the GRE-Striping-IP. Go to Configuration > Wireless > AP Configuration > click ‘edit’ next to the AP group the AP-225s will be in.
    Select the appropriate AP System Profile.
    Set the LMS-IP to point to the appropriate controller then set the GRE-Striping-IP.
    This must be the same as the mgmt. IP+1.
    #AP225
  • 3.  RE: AP225 GRE Stripping
    Posted Apr 22, 2014 02:21 PM
    Thanks. this really help.
    Chan
    #AP225
