Dear Collin,
The Aruba controller and the switch were already configured as per provided link.
However, I did go through the suggested steps.
The AP System profile on the controller is configures as per below:
ap system-profile "AP225"
lms-ip 10.181.4.110
gre-striping-ip 10.181.4.111
As suggested, I've plugged the AP to the switch using 1 cable outside of the port channel. Once AP was seen on Aruba, I've provisioned it with the AP225 profile as per configuration above.
Configured the port channel, added ports to it and plugged AP into the switch This causes the AP to lose its connection to the switch.
A show etherchannel summary gives me:
TEST_SWITCH#sh etherchannel summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 1
Number of aggregators: 1
Group Port-channel Protocol Ports
10 Po10(SD) LACP Fa1/0/3(D) Fa1/0/4(w)
A sh int status shows the ports as not connected:
Fa1/0/3 notconnect 267 auto auto 10/100BaseTX
Fa1/0/4 notconnect 267 auto auto 10/100BaseTX
However, on the interface intself I'm getting:
REGENTS_GATEWAY_TEST_SWITCH#sh int f1/0/4
FastEthernet1/0/4 is up, line protocol is down (notconnect)
I've consoled into the AP to log the activity and got the below output:
APBoot 1.4.0.6 (build 38177)
Built: 2013-04-25 at 22:52:20
Model: AP-22x
CPU0: P1020E, Version: 1.1, (0x80ec0011)
Core: E500, Version: 5.1, (0x80212051)
Clock:
CPU0: 800 MHz
CPU1: 800 MHz
CCB: 400 MHz
DDR: 333.333 MHz (666.667 MT/s data rate) (Asynchronous)
LBC: 25 MHz
L1: D-cache 32KB enabled
I-cache 32KB enabled
I2C: ready
DRAM: Configuring DDR for 666.667 MT/s data rate
DDR: 512 MB (DDR3, 32-bit, CL=5, ECC off)
POST1: memory passed
Flash: 32 MB
L2: 256 KB enabled
Power: 802.3af POE
PCIe1: RC, link up, x1
dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
00 00 14e4 43a2 00002 03 80000004 00000000 80200004 00000000
PCIe2: RC, link up, x1
00 00 14e4 43a1 00002 03 a0000004 00000000 a0200004 00000000
Net: eth0, eth1
Radio: bcm43460#0, bcm43460#1
Hit <Enter> to stop autoboot: 0
Checking image @ 0xee000000
Copying image from 0xee000000
Image is signed; verifying checksum... passed
Signer Cert OK
Policy Cert OK
RSA signature verified.
[ 0.000000]
[ 0.000000] Aruba Networks
[ 0.000000] ArubaOS Version 6.3.1.3 (build 42233 / label #42233)
[ 0.000000] Built by p4build@port-royal on 2014-02-11 at 11:15:36 PST (gcc version 4.5.1)
[ 0.000000]
[ 0.000000] Memory: 510388k/524288k available (8384k kernel code, 13900k reserved, 464k data, 355k bss, 5020k init)
[ 0.002959] Processor 1 found.
[ 0.113002] Brought up 2 CPUs
[ 0.189525] PCI: Probing PCI hardware
[ 0.232576] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 0.295578] pci 0001:02:00.0: PCI bridge to [bus 03-ff]
[ 0.357793] pci 0000:00:00.0: enabling device (0106 -> 0107)
[ 0.424988] pci 0001:02:00.0: enabling device (0106 -> 0107)
[ 4.024753] ee000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank
[ 4.099787] Amd/Fujitsu Extended Query Table at 0x0040
[ 4.161307] number of CFI chips: 1
[ 4.206438] /proc/gfar_eth0_stats created
[ 4.257123] /proc/gfar_eth1_stats created
[ 4.321128] wdg_create_new_proc_entry: proc initializedEnabling watchdog on CPU 1
[ 4.381611] Enabling watchdog on CPU 0
[ 4.462395]
[ 4.462400] Starting Kernel SHA1 KAT ...Starting Kernel HMAC SHA1 FIPS KAT ...Completed Kernel HMAC SHA1 FIPS KAT
[ 4.472491] Starting Kernel HMAC SHA256 FIPS KAT ...Completed Kernel HMAC SHA256 FIPS KAT
[ 4.473454] Starting Kernel HMAC SHA384 FIPS KAT ...Completed Kernel HMAC SHA384 FIPS KAT
[ 4.473909] Starting Kernel HMAC SHA512 FIPS KAT ...Completed Kernel HMAC SHA512 FIPS KAT
[ 4.474329] Starting Kernel AES-CBC FIPS KAT ...Completed Kernel AES-CBC FIPS KAT
[ 4.481091] Starting Kernel AES-CCM FIPS KAT ...Completed Kernel AES-CCM FIPS KAT
[ 4.481559] Starting Kernel 3DES-CBC FIPS KAT ...Completed Kernel 3DES-CBC FIPS KAT
[ 5.175012] Completed Kernel SHA1 KAT
[ 5.219827] Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
[ 5.307964] Starting Kernel DES KAT ...Completed Kernel DES KAT
[ 5.379916] Starting Kernel AES KAT ...Completed Kernel AES KAT
[ 5.423716]
Domain Name: arubanetworks.com
No panic info available
[ 7.075185] p1020_soc: P1020 Misc Utils Driver version 1
Ethernet port 1 mode: active-standby
[ 7.329645] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.399109] ADDRCONF(NETDEV_UP): bond0: link is not ready
[ 7.480179] bonding: bond0: enslaving eth0 as a backup interface with a down link.
[ 7.586816] bonding: bond0: enslaving eth1 as a backup interface with a down link.
[ 7.809753] AP xml model 66, num_radios 2 (jiffies 3701)
[ 7.873340] init_asap_mod: installation:0
[ 7.921285] radio 0: band 1 ant 0 max_ssid 16
[ 7.973392] radio 1: band 0 ant 0 max_ssid 16
[ 8.025506] ethernet_device_event: dev eth0 is up
[ 8.089570] ASAP Slowpath initialized
Starting watchdog process...
Got all network params from APboot env. Skipping DHCP
10.181.33.175 255.255.255.128 10.181.33.129
Running ADP...Done. Master is 10.181.4.110
[ 11.193567] PHY: eth0 (mdio@ffe24000:00) - Link is Up - 100/Full
[ 11.266050] PHY: eth1 (mdio@ffe24000:01) - Link is Up - 100/Full
[ 11.363063] wifi0: AP type AP-225, radio 0, max_bssids 16
[ 11.408015] bonding: bond0: link status definitely up for interface eth0.
[ 11.408026] bonding: bond0: making interface eth0 the new active one.
[ 11.408081] bonding: bond0: first active interface up!
[ 11.408087] bonding: bond0: link status definitely up for interface eth1.
[ 11.408251] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
[ 11.830026] Shutting down eth1 due to insufficient POE voltage [power profile 2]
[ 11.918754] Shutting down 2 2.4G radio TX/RX chains due to insufficient POE voltage[power profile 2]
[ 12.052692] wifi1: AP type AP-225, radio 1, max_bssids 16
Clearing P1020 PCIe Error Status
shutting down watchdog process (nanny will restart it)...
<<<<< Welcome to the Access Point >>>>>
~ # [ 14.769777] bonding: bond0: Warning: the permanent HWaddr of eth0 - 18:64:72:c5:d7:04 - is still in use by bond0. Set the HWaddr of eth0 to a different address to avoid conflicts.
[ 14.961524] bonding: bond0: releasing active interface eth0
[ 15.028271] bonding: bond0: making interface eth1 the new active one.
[ 15.120464] ethernet_device_event: dev eth0 is down
[ 15.183585] bonding: bond0: releasing active interface eth1
[ 15.276471] bonding: bond0: setting xmit hash policy to layer2+3 (2).
[ 15.353727] bonding: bond0: setting mode to balance-xor (2).
[ 15.431484] ADDRCONF(NETDEV_UP): bond0: link is not ready
[ 15.505278] ethernet_device_event: dev eth0 is up
[ 15.561658] bonding: bond0: enslaving eth0 as an active interface with an up link.
[ 15.652448] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
[ 15.727878] Disable device eth1 due to insufficient POE voltage.
[ 15.806185] Disable device eth1 due to insufficient POE voltage.
[ 18.726937] PHY: eth0 (mdio@ffe24000:00) - Link is Up - 100/Full
[ 72.085539] POE power conditions have improved: the new condition would be 'POE: No restrictions'
[ 76.385655] bonding: bond0: releasing active interface eth0
[ 76.466915] ethernet_device_event: dev eth0 is down
[ 76.547954] bonding: bond0: setting xmit hash policy to layer2+3 (2).
[ 76.625152] bonding: bond0: setting mode to balance-xor (2).
[ 76.693100] ADDRCONF(NETDEV_UP): bond0: link is not ready
[ 76.766205] ethernet_device_event: dev eth0 is up
[ 76.822562] bonding: bond0: enslaving eth0 as an active interface with an up link.
[ 76.913311] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
[ 76.988047] Disable device eth1 due to insufficient POE voltage.
[ 77.067812] Disable device eth1 due to insufficient POE voltage.
[ 80.052426] PHY: eth0 (mdio@ffe24000:00) - Link is Up - 100/Full
[ 137.148671] bonding: bond0: releasing active interface eth0
[ 137.228398] ethernet_device_event: dev eth0 is down
[ 137.299903] bonding: bond0: setting xmit hash policy to layer2+3 (2).
[ 137.377190] bonding: bond0: setting mode to balance-xor (2).
[ 137.445194] ADDRCONF(NETDEV_UP): bond0: link is not ready
[ 137.518339] ethernet_device_event: dev eth0 is up
[ 137.574716] bonding: bond0: enslaving eth0 as an active interface with an up link.
[ 137.665464] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
[ 137.740103] Disable device eth1 due to insufficient POE voltage.
[ 137.818324] Disable device eth1 due to insufficient POE voltage.
[ 140.946922] PHY: eth0 (mdio@ffe24000:00) - Link is Up - 100/Full
