AP225 & Os Vesrion
  • 1.  AP225 & Os Vesrion
    Posted Feb 21, 2014 05:52 AM
    is it supported only starting from 6.3.0 ?
  • 2.  RE: AP225 & Os Vesrion
    Posted Feb 21, 2014 05:54 AM
    Yes!
  • 3.  RE: AP225 & Os Vesrion
    Posted Feb 21, 2014 05:56 AM
    As per Datasheet of AP220 Series
    Minimum operating system software versions
    • ArubaOS 6.3.0.0
    • Aruba Instant 3.5.0.0*
  • 4.  RE: AP225 & Os Vesrion
    Posted Feb 21, 2014 09:49 AM
    Use code 6.3.1.3+ or 6.4.0.x for the AP225.
  • 5.  RE: AP225 & Os Vesrion
    Posted Feb 21, 2014 10:21 AM
    And correction to the Instant software version, it should be 4.0.0.0 not 3.5.0.0.
  • 6.  RE: AP225 & Os Vesrion
    Posted Feb 24, 2014 01:45 AM
    thanks madjali,
    The datasheet is also required this correction ;)
  • 7.  RE: AP225 & Os Vesrion
    Posted Feb 24, 2014 09:08 AM
    Syed,
    Which datasheet are you referring to? This one appears to be up to date:
    http://www.arubanetworks.com/pdf/products/DS_AP220Series.pdf
    Best regards,
    Madani
