last person joined: 7 hours ago
AP225 POE/POE+ power required to work in .11AC.
  • 1.  AP225 POE/POE+ power required to work in .11AC.
    Posted Jun 03, 2014 08:29 AM
     I have an 8 port Alcatel 6450 PoE/PoE+ Switch with a power budget of 120W. I would like to know the power required by AP225 to work in .11ac with unrestricted functionality. So that I can plan my power budget for the switch.
    I am wondering if all the 8 ports can support AP225 with full functionality.
    Please help with your inputs.
    Shabz
    #AP225
  • 2.  RE: AP225 POE/POE+ power required to work in .11AC.
    Posted Jun 03, 2014 09:02 AM
    The AP225 requires PoE+ to work with unrestricted functionality.
    #AP225
  • 3.  RE: AP225 POE/POE+ power required to work in .11AC.
    Posted Jun 03, 2014 09:10 AM
    The AP-225 does work with PoE with the following restrictions:
    - USB port disabled
    - Second Ethernet port disabled
     -2.4GHz 802.11n radio in 1×3:1SS mode
    >>> 5GHz 802.11ac radio operates without restrictions <<<
    Per the Data Sheet  the max power is 15W + 2.5W if the USB port is used.  This is power received at the AP......the switch would need to deliver more to account for losses through cabling and patch pannels.  Actual power used will vary by client load, client demand, and features used.
    #AP225
  • 4.  RE: AP225 POE/POE+ power required to work in .11AC.
    Posted Jun 03, 2014 10:08 AM
    We recently did some new testing based upon the new versions of AOS and determined the following maximum loads:
    Unrestricted mode / Max DC power: 15.5W
    Unrestricted mode / Max Powered Device (PD) power: 17W
    Restricted mode / Max Powered Device (PD) power: 13.5W
    * Above exclude USB consumption
    As Marcus said, the actual consumption will vary based upon client load, etc.
    #AP225
  • 5.  RE: AP225 POE/POE+ power required to work in .11AC.
    Posted Jun 04, 2014 01:31 AM
    Thanks guys for the valuable inputs...
    #AP225
  • 6.  RE: AP225 POE/POE+ power required to work in .11AC.
    Posted Jun 03, 2014 12:02 PM
    i mean 30W but 15.5W wrote on datasheet
    #AP225
