AP225 Power save mode issue (LLDP)
  • 1.  AP225 Power save mode issue (LLDP)
    Posted Mar 06, 2019 02:28 PM
    I am seeing an AP225 in power saving mode when using an injector. The injector is rated for 802.3at but the AP is not negotiating correctly.
    I have switched the power injector with no change. Here's the output:
    Power Status
    Operational State          POE-AF: One Ethernet port disabled; USB port disabled; 1x3 chain for 2.4GHz; 3x3 chain for 5GHz
    Current HW State           POE-AF: One Ethernet port disabled; USB port disabled; 1x3 chain for 2.4GHz; 3x3 chain for 5GHz
    LLDP Negotiated POE Power  0.0W
    Another AP on that same injector works fine. Changing the injector did not help. What should I do?
  • 2.  RE: AP225 Power save mode issue (LLDP)
    Posted Mar 06, 2019 04:12 PM
    Check the cable.
  • 3.  RE: AP225 Power save mode issue (LLDP)
    Posted Mar 08, 2019 11:13 AM
    Also check if the switchport has PoE enabled. I've had issues when we were using injectors for .at power but didn't disable it on the switchport. The APs would end up in power save mode.
  • 4.  RE: AP225 Power save mode issue (LLDP)
    Posted Mar 08, 2019 11:16 AM
    No PoE on the switch, it's an old 2960G. Pretty sure it's the cabling as was mentioned. The cabling in this building is shoddy.
