AP275 in Incattive status
  • 1.  AP275 in Incattive status
    Posted Mar 27, 2016 07:17 AM
    After having convert IAP 275 to AP 275 , and provisioning them with the correct AP-Group, it still appear Inactive (I Flag).
    In the same AP Group I have some AP 205 , that are  Properly functioning
    I have already check the regulatory domain , and AP are supposed to work properly in the FR (france) , regulatory domain.
    Can anyone help me with this issue Please ?
    Regards
  • 2.  RE: AP275 in Incattive status
    Posted Mar 27, 2016 07:54 AM
    When you type "show ap database", what is the flag next to that AP?
  • 3.  RE: AP275 in Incattive status
    Posted Mar 27, 2016 08:07 AM
    The flag is "I"  , inactive
  • 4.  RE: AP275 in Incattive status
    Posted Mar 27, 2016 08:34 AM
    Type "show log system 50" and see if you can see why.
    What is the regulatory domain of the controller?
    Type "show profile errors" to see if you have any other problems..
  • 5.  RE: AP275 in Incattive status
    Posted Mar 27, 2016 09:13 AM
    The regulatory domain of the controlleur is FR.
    and other AP ( AP 205) are correctly opearting
  • 6.  RE: AP275 in Incattive status
    Posted Mar 27, 2016 10:04 AM
    Check the output of "#show ap debug system-status ap-name <AP-NAME> | include POE".
    If the AP-275 has received POE-AF power, it'll come up with "I" flag.
    AP-275 needs POE-AT power for the radios to turn on.
  • 7.  RE: AP275 in Incattive status
    Posted Mar 27, 2016 10:59 AM
    * Check POE at the AP (you can plug in to the console port of the AP to see the output and if it's not enough power it will say so, or if you see the LED stay Red after powerup, then you know it's a POE issue (you need 802.3at with LLDP support on the swtch, or you can use an 802.3at power inejector, POE+ or 30W 802.3af is not supported)
    * Check your version of code, and if need be, upgrade the DRT file if you can't upgrade AOS firmware should it be needed. Doing a 'show ap allowed-channels country-code fr ap-type 275' and should see the following. If not, you need updated firmware or an update to the DRT
    (Aruba7005) # show ap allowed-channels country-code fr ap-type 275
    Allowed Channels for AP Type 275 Country Code "FR" Country "France"
    PHY Type                 Allowed Channels
    802.11g (indoor)         1 2 3 4 5 6 7 8 9 10 11 12 13
    802.11a (indoor)         36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
    802.11g (outdoor)        1 2 3 4 5 6 7 8 9 10 11 12 13
    802.11a (outdoor)        100 104 108 112 116 120 124 128 132 136 140
    802.11g 40MHz (indoor)   1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
    802.11a 40MHz (indoor)   36-40 44-48 52-56 60-64 100-104 108-112 116-120 124-128 132-136
    802.11g 40MHz (outdoor)  1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
    802.11a 40MHz (outdoor)  100-104 108-112 116-120 124-128 132-136
    802.11a 80MHz (indoor)   36-48 52-64 100-112 116-128
    802.11a 80MHz (outdoor)  100-112 116-128
    802.11a (DFS)            52 56 60 64 100 104 108 112 116 120 124 128 132 136 140\
  • 8.  RE: AP275 in Incattive status
    Posted Mar 28, 2016 05:53 AM
    Dear,
    thank you for your help,  the probleme was in the Power Source, the AP 275 was powered with 15.4 watt, after activing LLDP in the Cisco Switch , the AP worked properly (  the negotiation of the power source alimenation).
    Regards
