AP275 loosing config
  • 1.  AP275 loosing config
    Posted Feb 11, 2015 10:38 PM
    We are installing Aruba AP275's for a customer.   They do not have DHCP configured so we are statically assigning IP address, gateway IP, Name, Group, subnet mask, etc...
    We are using Cisco switches with an Aruba controller.  After installing roughly 50-275's we are occasionally finding a few random AP's with no config on them whatsoever.  So these AP's are obviously not being recognized by the controller.  What could cause a configured AP to loose its config?    THis also appeared to have happened on 1 AP225 as well.  Any thoughts would be apprieciated =.
    #AP225
  • 2.  RE: AP275 loosing config
    Posted Feb 11, 2015 10:45 PM
    How are you doing controller discovery?
  • 3.  RE: AP275 loosing config
    Posted Feb 11, 2015 11:08 PM
    LLDP
    When logged into the associated switch a:  show lldp neighbors shows just a mac address for this AP.
  • 4.  RE: AP275 loosing config
    Posted Feb 11, 2015 11:13 PM
    If it helps, the Controller is an Aruba 7240 and is running 6.4.2.0...
  • 5.  RE: AP275 loosing config
    Posted Feb 11, 2015 11:23 PM
    The discovery options would be ADP (broadcast if APs are in the same subnet as controller), DNS entry for Aruba-master pointed to the controller, or DHCP option 43. You might also try upgrading to 6.4.2.4 as well as there were a few fixed specifically for the 270 series
  • 6.  RE: AP275 loosing config
    Posted Feb 13, 2015 10:42 AM
    The Ip Addressing is hard coded in lab before installtion
