AP275 throughput test
  • 1.  AP275 throughput test
    Posted Sep 10, 2014 10:04 AM
    we are trying to proof the proposed speed of AP275, as we got Laptop with 802.11ac cpability , WLC3200 and wired ethernet card with 1Gbps speed.
    is there any such tests from Aruba?????
  • 2.  RE: AP275 throughput test
    Posted Sep 10, 2014 10:35 AM
    You can use iPerf.
  • 3.  RE: AP275 throughput test
    Posted Sep 11, 2014 02:27 AM
    every body said that, but the problem is that there is no one can give detailed test using Iperf, and the exact criteria to acheive high throughput on this product.
  • 4.  RE: AP275 throughput test
    Posted Sep 11, 2014 03:22 AM
    Hi
    You don't need to setup anything special on the Aruba for using Iperf.
    What you need is two computers, both running Iperf.
    How you can set it up, you can find here: https://iperf.fr/
    Iperf can be used as both a client and server, this way you can measure speed to and from a site. Or you can setup 2 tests at the same time, to simulate traffic both ways.
    Roar Fossen
