AP303 stuck in boot sycle "runing ADP...."
This thread has been viewed 37 times
  • 1.  AP303 stuck in boot sycle "runing ADP...."
    Posted Jul 26, 2022 10:48 PM
    I have an Aruba 303 AP  that once was used in a controller (mobility master) enviorment.
    I am booting it in a LAB with no controller and keep getting this "runnig ADP..."  and after a minute it is getting  "Running ADP /tmp/master No such file or directory".
    I did a factory_reset with console
    and try to do with the actual bottun but still see the old AP name in IP_Scann  and cannot boot it.
    any help please.
    Hit <Enter> to stop autoboot: 0
    Checking image @ 0x0
    Invalid image format version: 0x0
    Checking image @ 0x2000000
    Copying image from 0x84000000
    Image is signed; verifying checksum... passed
    SHA2 Signature available
    Signer Cert OK
    Policy Cert OK
    RSA signature verified using SHA2.
    Uncompressing Kernel Image ... OK
    [ 0.000000]
    [ 0.000000] Aruba Networks
    [ 0.000000] ArubaOS Version 6.5.2.0 (build 58369 / label #58369)
    [ 0.000000] Built by p4build@naxos on 2017-02-10 at 02:04:23 PST (gcc version 4.6.3)
    [ 0.000000]
    [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
    [ 0.039270] SMP: Total of 4 processors activated (384.00 BogoMIPS).
    [ 0.087818] i2c-gpio driver registered
    [ 5.825797] 3 ofpart partitions found on MTD device 7980000.qcom,nand
    [ 5.890448] Creating 3 MTD partitions on "7980000.qcom,nand":
    [ 5.959194] 0x000000000000-0x000002000000 : "aos0"
    [ 6.058953] 0x000002000000-0x000004000000 : "aos1"
    [ 6.145975] 0x000004000000-0x000008000000 : "ubifs"
    [ 6.291403] m25p80 spi0.0: found mx25r3235f, expected n25q128a11
    [ 6.446916] Found AT97SC3203 on i2c_1.8
    [ 6.488529] Key type dns_resolver registered
    [ 6.531456] Registering SWP/SWPB emulation handler
    [ 8.253536] TZ dump found for reboot
    [ 8.321331]
    Starting Kernel SHA1 KAT ...
    [ 8.355805] Completed Kernel SHA1 KAT
    [ 8.402696] Starting Kernel HMAC-SHA1 KAT ...
    [ 8.452852] Starting Kernel DES KAT ...[ 8.498567] Completed Kernel DES KAT
    [ 8.542288] Starting Kernel AES KAT ...
    [ 8.586078] Completed Kernel AES KAT
    [ 8.586078]
    [ 8.649703] Starting Kernel AESGCM KAT ...
    [ 8.696391] Completed Kernel AESGCM KAT
    [ 8.745739] Completed Kernel HMAC-SHA1 KAT
    AP-type has_ble_support: ONBOARD.
    Domain Name: arubanetworks.com
    No panic info available
    Writing /dev/ttyMSM1 into /tmp/ble_port
    Enabling ble_daemon via nanny
    [ 15.621676] edma module_init
    [ 16.546897] drvlog_mod: module license 'Proprietary' taints kernel.
    [ 16.609486] Disabling lock debugging due to kernel taint
    Starting watchdog process...
    Getting an IP address...
    [ 21.684159] bond0: GMAC Link is up with phy_speed=1000
    10.0.0.4 255.255.255.0 10.0.0.138
    Running ADP...
    ( And after a minute or so)
    Running ADP...cat: /tmp/master: No such file or directory
    Done. Master is
    killall: nanny: no process killed
    killall: sapd: no process killed
    Sending SIGKILL to all processes.
    Unmounting UBIFS completed.
    Please stand by while rebooting the system.
    [ 98.593041] reboot: Restarting system
  • 2.  RE: AP303 stuck in boot sycle "runing ADP...."
    Posted Jul 27, 2022 01:22 AM
    when you did the hw reset, did you press and held the reset button and then connected the poe or power adapter and then held it for 5 sec or so?
    if you have a console connection you a few messages about erasing image.
  • 3.  RE: AP303 stuck in boot sycle "runing ADP...."
    Posted Jul 27, 2022 01:32 AM
    I did this.
    And also factory reset from the apboot.
    If it is an AP version and not API, then it will not boot without a controller?
  • 4.  RE: AP303 stuck in boot sycle "runing ADP...."
    Posted Jul 27, 2022 02:00 AM
    AP-303 can be IAP as well
    I encounter similar issue like this
    https://community.arubanetworks.com/community-home/digestviewer/viewthread?MID=33403
    Here how I fix
    1. erase first by pressing and hold hole at the bottom for 5s while plugging ethernet poe
    2. follow this and set static ip and upload using latest firmware
    https://acmxguy.wordpress.com/2020/05/06/aruba-iap-ap-boot-image-upgrade/
  • 5.  RE: AP303 stuck in boot sycle "runing ADP...."
    Posted Jul 27, 2022 04:20 AM
    That did it!
    Thank you!!!
  • 6.  RE: AP303 stuck in boot sycle "runing ADP...."
    Posted Jul 27, 2022 03:37 AM
    HI Gtaboy34,
    it looks like it is trying to find a controller to boot from.
    If you do have a controller in the lab make sure that it can PING the AP on 10.0.0.4.
    If you are running it stand alone it will need to have IAP-303 on the label on the back and not AP-303
    Cheers,
    Ewan.
  • 7.  RE: AP303 stuck in boot sycle "runing ADP...."
    Posted Feb 06, 2024 04:59 AM
    You can install Instant image with upgrade command from boot prompt as it is discussed in this thread.
    Short recap.
    1. Connect console cable
    2. Power on AP
    3. Interrupt boot proces
    4. boot> dhcp
    5. boot> serverip <ip address of tftp server>
    6. boot> upgrade os 0 <instant ap image name>
    7. boot> boot
