Hello I am hoping there is an Aruba Document for installing the AP305 using the mounting kit. Similar to the AP install document that shows the drop ceiling bracket. We are putting together documentation for our on site help.
It depends which mount you got: https://www.arubanetworks.com/assets/og/OG_AP-300Series.pdf
All of the AP mount installation guides are found on support.arubanetworks.com (no login required) under 'Documentation'. If you aren't finding what you need, let us know.
@jhoward wrote:All of the AP mount installation guides are found on support.arubanetworks.com (no login required) under 'Documentation'. If you aren't finding what you need, let us know.
That's where it's at, found it. Thanks for your help
We use JY705ADidn't think about the fact there are multiple mounts, we always order the same one.
