We need to install AP314 with external antenna AP-ANT-45.
The AP314 has four RP-SMA connectors (ANT0-ANT3).
I haven’t found anything for installation about the specific combination (AP port to Antenna port).
Do we need to follow a specific order and mapping ?
For example the ANT0 to the first cable of the external antenna ? or it doesn’t matter ?
If yes can you please specify how we count the cables from the external antenna as there is not any identification or numbering.
Thank you
