AP325 and GRE Striping IP configuration
  • 1.  AP325 and GRE Striping IP configuration
    Posted Jul 21, 2017 08:41 AM
    Hi all,
         I have read a lot of post about it but i have one doubt:
    I have 2 controller in a master/local scenario in different L3 networks, I also have some AP Groups configured with LMS and LMP backup IP configured.
    I have to configure a new building with ap325 and lacp aggregation, my doubt is: referring to
    http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Content/ArubaFrameStyles/AP_Config/LACP_Support_on_AP_220.htm
     the "AP LACP LMS map information" configuration seem a global configuration, could it create problem with others running groups/aps?
  • 2.  RE: AP325 and GRE Striping IP configuration
    Posted Jul 24, 2017 10:48 PM
    Hi Mauro,
    1. Are you adding AP-325's for the first time on the network?
    2. Does the existing network has any of the  AP-220 Series , AP-270 Series, and AP-320 AP's?
  • 3.  RE: AP325 and GRE Striping IP configuration
    Posted Jul 25, 2017 03:22 AM
    Hi Nitesh,
       my network is composed only by IAP-325, I have the HQ and some branch offices already with 325. I have to setup a new brach office with the dual cable and the lacp config.
  • 4.  RE: AP325 and GRE Striping IP configuration
    Posted Jul 31, 2017 08:29 AM
    Asked to the support, that's the solution:
    the field is global but doesn't interfere with other group, in the selected group I have to set in "no shut" the enet0 and enet1, plus the switch configuration for LACP.
