AP374 and a 4x4 D608 ANT
  • 1.  AP374 and a 4x4 D608 ANT
    Posted Feb 07, 2019 08:42 PM
    Hey @onno
    A customer asked me a question...
    If they have an AP374 and a 4x4 D608 ANT, can two be connected to 2.4GHz and two be connected to 5GHz? For 2x2 2.4GHz and 2x2 5GHz using a single D608? They would only be doing this for test purposes. The final solution being all $ connected to 5GHz and a separate ANT for the 2x2 2.4GHz.
    Looking at the makeup of the 4x4 D608 ANT, I said I would not recommend it but I would verify with you guys if it could be done or not.
  • 2.  RE: AP374 and a 4x4 D608 ANT
    Posted Feb 08, 2019 02:07 AM
    Yes, you could do this.
    Make sure to connect antenna ports 0 and 1.
    That means you're leaving antennas 2 and 3 on 5GHz unconnected.
    Not recommended (we have no way to disable 3SS and 4SS operation), but it'll work. They should terminate the unused ports with dummy loads.
  • 3.  RE: AP374 and a 4x4 D608 ANT
    Posted Feb 08, 2019 12:27 PM
    Thanks man. As for the ANT.. it has 4 ports.
    -45
    +45
    V
    H
    How should those correspond to the 374 ports 5GHz 0,1 and 2,4GHz 0,1?
    Thanks again @onno
  • 4.  RE: AP374 and a 4x4 D608 ANT
    Posted Feb 08, 2019 07:51 PM
    Use +/- 45 for one radio, V and H for the other
  • 5.  RE: AP374 and a 4x4 D608 ANT
    Posted Feb 10, 2019 11:10 AM
    Thanks again @onno
