Dear Aruba Team,
I am configuring Aruba AP505,
it shows Setmeup: ssid, after connection done
Opening the web access
https://setmeup.arubanetworks.com:4343/ and asking password
once enter the user name and default password,
asking to reset the password, also done successfully
then i logged in with new password, it is asking to select the country.
after i select the country and click ok,
SSID lost and disconnected - i tried many times but no luck.
one of our support guy asked me to ping the ips
192.168.3.1 - not pining
172.31.82.1 (gateway getting while connecting via Setmeup wifi) also not pinging
i used power adapter and connect directly to the laptop, even not connecting
pls give me the solution, for the last 3 days i am stuck up here.
Regards
Haleem
Abdul Haleem
haleem@ibookerp.com00971 50 777 5940
