AP515 IAP unable to browse to certain websites/services
This thread has been viewed 22 times
  • 1.  AP515 IAP unable to browse to certain websites/services
    Posted Jan 16, 2020 10:37 AM
    We are testing an AP515 as an Instant AP. We have set up the unit with basic settings, one SSID with WPA2 personal encryption. We are using networked defined VLAN and IP addressing on an existing network that works. We are able to connect and get network access but are unable to browse to certain websites like google and other google services (youtube etc) but other websites work fine. We have tried tweaking the policies and adding explicit any to any allow rules and various services but doesn't seem to change anything. Anyone know why this might happen?
    We are using AP515 in the same environment as campus APs on a cluster and don't experience anything like this. I have tested IAP in another environment and it worked fine with basic settings although was on an older model of AP. Is there something different about 515s or the IAP software they run?
    Thanks.
  • 2.  RE: AP515 IAP unable to browse to certain websites/services
    Posted Jan 16, 2020 10:49 AM
    Have you tried with Unrestricted access on the network configuration?
  • 3.  RE: AP515 IAP unable to browse to certain websites/services
    Posted Jan 16, 2020 10:53 AM
    Hi thanks for reply. We have tried with this unrestricted setting and still same results.
  • 4.  RE: AP515 IAP unable to browse to certain websites/services
    MVP EXPERT
    Posted Jan 16, 2020 11:01 AM
    Are you able to resolve the URL of the problematic sites, to confirm DNS is working? Is there any difference in the sites such as HTTP or HTTPS? Any transparent proxies upstream?
    Grab one of the IPs of the URLs which is failing and check the datapath session. You might see Y flag which means there is no syn.
    show datapath session | include [IP OF WEB SITE]
  • 5.  RE: AP515 IAP unable to browse to certain websites/services
    Posted Jan 16, 2020 11:45 AM
    Thanks for reply. DNS is working ok as lookups resolve. If we browse to a URL for example youtube.com in Chrome it attempts to connect to http without redirecting to https. If we add https in it will partially load the webpage but lots of content won't load within the page. Other pages like google search or reddit won't load at all. No proxy involved on our network. Firefox and Chrome show connection reset errors so presume is something to do with traffic or TCP messing up but is beyond my knowledge.
    I will check the datapatch command now. Thanks.
  • 6.  RE: AP515 IAP unable to browse to certain websites/services
    Posted Jan 16, 2020 12:07 PM
    We are indeed seeing the 'no SYN' flag for sessions to websites. I understand this means there is an issue with the 3 way handshake?
  • 7.  RE: AP515 IAP unable to browse to certain websites/services
    MVP EXPERT
    Posted Jan 16, 2020 12:10 PM
    That is correct, this means the AP is not seeing a reply. Can you check again the upstream devices.
    Sent from my iPad
  • 8.  RE: AP515 IAP unable to browse to certain websites/services
    Posted Jun 21, 2021 12:33 PM
    Was there ever a fix determined for this issue.  Experiencing the same thing (unable to reach certain websites - Google) with not logical explanation.  We've been running these AP515s for some time with no issues until recently.  What makes it even more unexplainable is that some APs work and others don't and it can be quite random.  After a reload some APs may start working again but the issue comes back.  Any input would be greatly appreciated.
    Thank you.
