Hi All,
I have the following strangeness in my environment:
AP60 provisioned with only antenna number 2
If I do the following command:
show ap debug radio-stats ap-name "GL-AP06-S_AFZ" radio 0 advanced
I see:
RADIO Stats
Parameter Value
------------------- General Per-radio Statistics
Total Radio Resets 1
Resets Beacon Fail 0
Resets BeacQ Stuck 0
Resets Fatal Intr 0
Resets RX Overrun 0
Resets RF Gain 1
Resets MTU Change 0
Resets TX Timeouts 0
POE-Related Resets 0
External Reset 0
TX Power Changes 1
Channel Changes 6
Radio Band Changes 6
Current Noise Floor 103
Avail TX Buffers 200
11g Protection 0
Last TX Antenna 1
Last RX Antenna 2
Scan Requests 0
Scan Rejects 0
Load aware Scan Rejects 0
PS aware Scan Rejects 0
Voice aware Scan Rejects 0
Video aware Scan Rejects 0
UAPSD Scan Rejects 0
Post radar related scan Rejects 0
CABQ traffic Scan Rejects 0
Radio Reset Scan Rejects 0
Queue Drain Scan Rejects 0
Scan Success 0
EIRP 12
MAX EIRP 20
UAPSD SP Reset 2
Channel Reuse Disabled 15227220
Dummy008 1
Dummy009 1
Dummy012 0
Dummy013 0
------------------- Transmit Specific Statistics
Frames Rcvd For TX 1079344
Tx Frames Dropped 5601
Frames Transmitted 1073743
PS Unicast 0
DTIM Broadcast 0
Success With Retry 230169
Tx Mgmt Frames 15255101
Beacons Transmitted 15227220
Tx Probe Responses 27341
Tx Data Frames 1051463
Tx Data Bytes 0
Multicast Data 342677
Tx CTS Frames 0
DTIM Timeouts 0
Dropped After Retry 5601
Dropped No Buffer 0
Missed ACKs 363791
Failed Beacons 3
Multi-Beacon Fail 0
Long Preamble 1079344
Short Preamble 0
Beacon Interrupts 15227223
TX Interrupts 1616994
FIFO Underrun 0
Allocated Desc 1079344
Freed Desc 1079344
Tx EAPOL Frames 0
Tx AGGR Good 0
Tx AGGR Unaggr 0
Tx 6 Mbps 15599083
Tx 9 Mbps 788
Tx 12 Mbps 3309
Tx 18 Mbps 2483
Tx 24 Mbps 94380
Tx 36 Mbps 606521
Tx WMM [VO] 27881
UAPSD OverflowDrop 0
TX Timeouts 0
Lost Carrier Events 0
HT40 Hang Detected 0
HT40 Hang Stuck 0
HT40 DFS RST WAR 0
HT40 DFS IMM WAR 0
HT40 DFS HT20 WAR 0
Tx MAC/BB Hang Stuck 0
------------------- Receive Specific Statistics
Last SNR 10
Last ACK SNR 10
Frames Received 2818819
Good Frames 2582233
Bad Frames 236586
Channel Busy 1s 0
Channel Busy 4s 0
Channel Busy 64s 0
Discarded Events 9980228
ARM Scan Frames 0
Rx Data Frames 780439
Rx Data Bytes 0
Null Data Frames 0
Rx Mgmt Frames 210185
Control Frames 1591609
Frames To Me 601939
Broadcast Frames 165424
Beacons Received 161533
Probe Requests 39360
Rx Probe Responses 7698
Rx RTS Frames 212152
Rx CTS Frames 3
ACK Frames 1379454
PS Poll Frames 0
CRC Errors 236586
PLCP Errors 31081
Rx Frames Dropped 589526
PHY Events 2982873
RADAR Events 0
RX Interrupts 12154983
RX Overrun 0
Rx 6 Mbps 1301899
Rx 9 Mbps 295
Rx 12 Mbps 8951
Rx 18 Mbps 5319
Rx 24 Mbps 758693
Rx 36 Mbps 507076
Randomly I see the following values reported antenna 1 (TX or RX)
Last TX Antenna 1
Last RX Antenna 2
Is it normal?
Thanks and Best Regards
Gian
#AP103
