Aruba Instant Wi-Fi: Meet the controllerless Wi-Fi solution that's easy to set-up, is loaded with security and smarts, and won't break your budget.
AP615 (fw 8.11.0.1) cannot enable 6ghz...
This thread has been viewed 16 times
  • 1.  AP615 (fw 8.11.0.1) cannot enable 6ghz...
    Posted 7 days ago
    How do I enable 6ghz radio to AP615?
    In Configuration menu in AP Config -> Radio I have changed Flexible dual radio to 5G/6G and all SSID's (Networks) I have enabled RF Band 6GHz plus there is default RF profile for 6GHz and 6GHz led stays off...
    I have tested ap also in "normal" mode (2.4/5G) and both radios will come up no problem. Flex dual mode 2.4/6G gives me only 2.4...
    Any ideas how to proceed??
    Jori Luoto
  • 2.  RE: AP615 (fw 8.11.0.1) cannot enable 6ghz...
    MVP GURU
    Posted 7 days ago
    Have you checked to see what mode it is set to? Monitor mode, Spectrum mode, or access?
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
  • 3.  RE: AP615 (fw 8.11.0.1) cannot enable 6ghz...
    Posted 7 days ago
    Both radios are in access mode.
    Jori Luoto
  • 4.  RE: AP615 (fw 8.11.0.1) cannot enable 6ghz...
    MVP GURU
    Posted 7 days ago
    Is the SSID configured to use WPA3 encryption. This is a pre-req.
    Dustin Burns
  • 5.  RE: AP615 (fw 8.11.0.1) cannot enable 6ghz...
    Posted 7 days ago
    VERY GOOD POINT!
    No it's not! Will test tomorrow to create different 6G SSID w/ WPA3..
    Jori Luoto
