AP615 support for AOS 8.10.x
This thread has been viewed 16 times
  • 1.  AP615 support for AOS 8.10.x
    Posted Nov 25, 2022 05:34 AM
    Hello
    Will the AP615 only be supported in version 8.11.0.x?
    Or is there a chance it will eventually be supported in the 8.10.0.x?
    I am asking this because the 8.10.0.x is a Long supported release and the AP630 and AP650 are supported in this version.
    Thank you
  • 2.  RE: AP615 support for AOS 8.10.x
    Posted Nov 25, 2022 05:46 AM
    The AP615 will require 8.11 or up as specified in the datasheet. I'm quite sure it will not be supported by 8.10 because new AP platforms are only added in major releases, which is 8.11 for the AP615.
