You can type "show audit-trail" on the controller and see how you configured that AP to get an idea of the the ip addressing information or the master controller ip address had a mistake. You can then change the controller to match what you changed so that the AP can re-join the controller. You can only wipe the config of an AP65 that cannot contact a controller using SOE or using the y-Cable.
