AP70s do not register to Controller 800! Help!!
  • 1.  AP70s do not register to Controller 800! Help!!
    Posted Aug 29, 2012 11:20 AM
    Does anyone here use Aruba 800 wireless controllers and AP70 on
    their network ?   I am setting up this new wireless network with the
    above equipment.  The wireless controllers are up on the network and
    I can ping them, HTTPS to them however i can not get the APs to
    register to the controller.
    1) When i plug the APs to the switch they are getting an IP address
    and I can ping them however it seems like they're going up down (
    switchports are going from amber to green).   Do I need some kind of
    special cable for the APs?  I went to configuration manual and follow
    every step for the AP configuration and they are still not showing in
    controller.
    2) How do i provision the APs to communicate with the controller ?
    controller config :
    show run
    Building Configuration...
    version 2.4
    enable secret "aa7891c511763a0428a019803059aeef65df5a3d3be23cc1"
    enable "8L8E8N0T0Z0F8N5[5[8N"
    hostname "aruba-master"
    logging level warnings stm
    clock summer-time UTC-5 recurring first sunday april 02:00 last sunday
    october 02:00
    clock timezone UTC -5
    ip access-list session validuser
      any any any permit
    vpn-dialer default-dialer
      ike authentication PRE-SHARE 218d0f532708d2c0a9963544c5733235dd78c9b696abed06
    user-role ap-role
    user-role pre-employee
    user-role trusted-ap
    user-role guest
    --More-- (q) quit (u) pageup (/) search (n) repeat
    user-role stateful-dot1x
    user-role logon
    aaa derivation-rules user
      set role condition essid equals "aruba-master" set-value pre-employee
    aaa mgmt-authentication mode enable
    aaa pubcookie-authentication
    aaa dot1x enforce-machine-authentication
     mode disable
    dot1x timeout wpa-key-timeout 1
    interface mgmt
            shutdown
    interface loopback
            ip address X.X.X.X
    vlan 6
    interface fastethernet 1/0
            description "fe1/0"
            trusted
            switchport access vlan 6
    interface fastethernet 1/1
            description "fe1/1"
            trusted
    interface fastethernet 1/2
            description "fe1/2"
            trusted
    interface fastethernet 1/3
            description "fe1/3"
            trusted
    interface fastethernet 1/4
            description "fe1/4"
            trusted
    interface fastethernet 1/5
            description "fe1/5"
            trusted
    interface fastethernet 1/6
            description "fe1/6"
            trusted
    interface fastethernet 1/7
            description "fe1/7"
            trusted
    interface gigabitethernet  1/8
            description "gig1/8"
            trusted
            switchport mode trunk
    interface vlan 1
    interface vlan 6
            ip address X.X.X.X X.X.X.X
    ip default-gateway X.X.X.X
    country US
    ap location 0.0.0
    ap-logging level informational snmpd
    double-encrypt disable
    ap-logging level informational sapd
    ap-logging level warnings am
    ap-logging level warnings stm
    max-imalive-retries 10
    bkplms-ip 0.0.0.0
    opmode opensystem
    mode ap_mode
    authalgo opensystem
    rts-threshhold 2333
    tx-power 2
    max-retries 4
    dtim-period 1
    max-clients 64
    beacon-period 100
    power-mgmt enable
    ageout 1000
    hide-ssid disable
    deny-bcast disable
    rf-band g
    bootstrap-threshold 7
    local-probe-response enable
    max-tx-fail 0
    forward-mode tunnel
    native-vlan-id 1
    arm assignment disable
    arm client-aware enable
    arm scanning disable
    arm scan-time 110
    arm scan-interval 10
    arm multi-band-scan disable
    arm voip-aware-scan enable
    arm max-tx-power 4
    arm rogue-ap-aware disable
    voip call-admission-control disable
    voip drop-sip-invite-for-cac disable
    voip active-load-balancing disable
    voip vocera-call-capacity 10
    voip sip-call-capacity 10
    voip svp-call-capacity 10
    voip sccp-call-capacity 10
    voip call-handoff-reservation 20
    voip high-capacity-threshold 20
    essid "XXX_Wireless"
    vlan-id 6
    weptxkey 1
    ap-enable enable
      phy-type a
        channel 36
        rates 6,12,24
        txrates 6,9,12,18,24,36,48,54
        essid "aruba-master"
        vlan-id 6
        opmode opensystem
        deny-bcast enable
        hide-ssid disable
      phy-type g
        short-preamble enable
        channel 1
        rates 1,2
        txrates 1,2,5,11,6,9,12,18,24,36,48,54
        bg-mode mixed
        dtim-period 3
    ap location 0.0.0
      phy-type enet1
        mode active-standby
        switchport mode access
        switchport access vlan 1
        switchport trunk native vlan 1
        switchport trunk allowed vlan ALL
        trusted disable
    wms
     general poll-interval 60000
     general poll-retries 2
     general ap-ageout-interval 30
     general sta-ageout-interval 30
     general ap-inactivity-timeout 5
     general sta-inactivity-timeout 60
     general grace-time 2000
     general laser-beam enable
     general laser-beam-debug disable
     general wired-laser-beam disable
     general stat-update enable
     general am-stats-update-interval 0
     ap-policy learn-ap enable
     ap-policy classification disable
     ap-policy protect-unsecure-ap enable
     ap-policy detect-misconfigured-ap disable
     ap-policy protect-misconfigured-ap disable
     ap-policy protect-mt-channel-split disable
     ap-policy protect-mt-ssid disable
     ap-policy detect-ap-impersonation disable
     ap-policy protect-ap-impersonation disable
     ap-policy beacon-diff-threshold 50
     ap-policy beacon-inc-wait-time 3
     ap-policy min-pot-ap-beacon-rate 25
     ap-policy min-pot-ap-monitor-time 2
     ap-policy protect-ibss disable
     ap-policy ap-load-balancing disable
     ap-policy ap-lb-max-retries 8
     ap-policy ap-lb-util-high-wm 90
     ap-policy ap-lb-util-low-wm 80
     ap-policy ap-lb-util-wait-time 30
     ap-policy ap-lb-user-high-wm 255
     ap-policy ap-lb-user-low-wm 230
     ap-policy persistent-known-interfering disable
     ap-config short-preamble disable
     ap-config privacy disable
     ap-config wpa disable
     station-policy protect-valid-sta disable
     station-policy handoff-assist disable
     station-policy rssi-falloff-wait-time 4
     station-policy low-rssi-threshold 20
     station-policy rssi-check-frequency 3
     station-policy detect-association-failure disable
     global-policy detect-bad-wep disable
     global-policy detect-interference disable
     global-policy interference-inc-threshold 100
     global-policy interference-inc-timeout 30
     global-policy interference-wait-time 30
     event-threshold fer-high-wm 0
     event-threshold fer-low-wm 0
     event-threshold frr-high-wm 16
     event-threshold frr-low-wm 8
     event-threshold flsr-high-wm 16
     event-threshold flsr-low-wm 8
     event-threshold fnur-high-wm 0
     event-threshold fnur-low-wm 0
     event-threshold frer-high-wm 16
     event-threshold frer-low-wm 8
     event-threshold ffr-high-wm 16
     event-threshold ffr-low-wm 8
     event-threshold bwr-high-wm 0
     event-threshold bwr-low-wm 0
     valid-11b-channel 1 mode enable
     valid-11b-channel 6 mode enable
     valid-11b-channel 11 mode enable
     valid-11a-channel 36 mode enable
     valid-11a-channel 40 mode enable
     valid-11a-channel 44 mode enable
     valid-11a-channel 48 mode enable
     valid-11a-channel 149 mode enable
     valid-11a-channel 153 mode enable
     valid-11a-channel 157 mode enable
     valid-11a-channel 161 mode enable
     valid-11a-channel 165 mode enable
     ids-policy signature-check disable
     ids-policy rate-check disable
     ids-policy dsta-check disable
     ids-policy sequence-check disable
     ids-policy mac-oui-check disable
     ids-policy eap-check disable
     ids-policy ap-flood-check disable
     ids-policy adhoc-check disable
     ids-policy wbridge-check disable
     ids-policy sequence-diff 300
     ids-policy sequence-time-tolerance 300
     ids-policy sequence-quiet-time 900
     ids-policy eap-rate-threshold 10
     ids-policy eap-rate-time-interval 60
     ids-policy eap-rate-quiet-time 900
     ids-policy ap-flood-threshold 50
     ids-policy ap-flood-inc-time 3
     ids-policy ap-flood-quiet-time 900
     ids-policy signature-quiet-time 900
     ids-policy dsta-quiet-time 900
     ids-policy adhoc-quiet-time 900
     ids-policy wbridge-quiet-time 900
     ids-policy mac-oui-quiet-time 900
     ids-policy rate-frame-type-param assoc channel-threshold 30
     ids-policy rate-frame-type-param assoc channel-inc-time 3
     ids-policy rate-frame-type-param assoc channel-quiet-time 900
     ids-policy rate-frame-type-param assoc node-threshold 30
     ids-policy rate-frame-type-param assoc node-time-interval 60
     ids-policy rate-frame-type-param assoc node-quiet-time 900
     ids-policy rate-frame-type-param disassoc channel-threshold 30
     ids-policy rate-frame-type-param disassoc channel-inc-time 3
     ids-policy rate-frame-type-param disassoc channel-quiet-time 900
     ids-policy rate-frame-type-param disassoc node-threshold 30
     ids-policy rate-frame-type-param disassoc node-time-interval 60
     ids-policy rate-frame-type-param disassoc node-quiet-time 900
     ids-policy rate-frame-type-param deauth channel-threshold 30
     ids-policy rate-frame-type-param deauth channel-inc-time 3
     ids-policy rate-frame-type-param deauth channel-quiet-time 900
     ids-policy rate-frame-type-param deauth node-threshold 20
     ids-policy rate-frame-type-param deauth node-time-interval 60
     ids-policy rate-frame-type-param deauth node-quiet-time 900
     ids-policy rate-frame-type-param probe-request channel-threshold 200
     ids-policy rate-frame-type-param probe-request channel-inc-time 3
     ids-policy rate-frame-type-param probe-request channel-quiet-time 900
     ids-policy rate-frame-type-param probe-request node-threshold 200
     ids-policy rate-frame-type-param probe-request node-time-interval 15
     ids-policy rate-frame-type-param probe-request node-quiet-time 900
     ids-policy rate-frame-type-param probe-response channel-threshold 200
     ids-policy rate-frame-type-param probe-response channel-inc-time 3
     ids-policy rate-frame-type-param probe-response channel-quiet-time 900
     ids-policy rate-frame-type-param probe-response node-threshold 150
     ids-policy rate-frame-type-param probe-response node-time-interval 15
     ids-policy rate-frame-type-param probe-response node-quiet-time 900
     ids-policy rate-frame-type-param auth channel-threshold 30
     ids-policy rate-frame-type-param auth channel-inc-time 3
     ids-policy rate-frame-type-param auth channel-quiet-time 900
     ids-policy rate-frame-type-param auth node-threshold 30
     ids-policy rate-frame-type-param auth node-time-interval 60
     ids-policy rate-frame-type-param auth node-quiet-time 900
     ids-signature "ASLEAP"
       mode enable
       frame-type beacon ssid asleap
     ids-signature "Null-Probe-Response"
       mode enable
       frame-type probe-response ssid-length 0
     ids-signature "AirJack"
       mode enable
       frame-type beacon ssid AirJack
     ids-signature "NetStumbler Generic"
       mode enable
       payload 0x00601d 3
       payload 0x0001 6
     ids-signature "NetStumbler Version 3.3.0x"
       mode enable
       payload 0x00601d 3
       payload 0x000102 12
     ids-signature "Deauth-Broadcast"
       mode enable
       frame-type deauth
       dst-mac ff:ff:ff:ff:ff:ff
    site-survey calibration-max-packets 256
    site-survey calibration-transmit-rate 500
    site-survey rra-max-compute-time 600000
    site-survey max-ha-neighbors 3
    site-survey neighbor-tx-power-bump 2
    site-survey ha-compute-time 0
    arm min-scan-time 8
    arm ideal-coverage-index 5
    arm acceptable-coverage-index 2
    arm wait-time 15
    arm free-channel-index 25
    arm backoff-time 240
    arm error-rate-threshold 0
    arm error-rate-wait-time 30
    arm noise-threshold 0
    arm noise-wait-time 120
    ems server-ip 0.0.0.0
    crypto isakmp groupname changeme
    vpdn group l2tp
      ppp authentication PAP
    masterip 127.0.0.1
    location "Building1.floor1"
    mobility
      parameters 60 buffer 32
      manager disable
      proxy-dhcp enable
      station-masquerade enable
      on-association disable
      trusted-roam disable
      ignore-l2-broadcast disable
      block-dhcp-release disable
      no new-user-roaming
      max-dhcp-requests 4
      secure 1000 shared-secret 4012c7accbe0f26bbb1703b4bf36dfa0
    mobility-local
      local-ha disable
    mobagent
      home-agent parameters 1000 bindings 300
      secure-mobile spi 1000 3abd01a8027810fb5dad94d4bacadec7
      foreign-agent parameters 1100 bindings 300 pending 0 pending-time 300
    syslocation "1501 Wilson BLVD"
    syscontact "Christina Antonetti"
    snmp-server new traps
    vpdn group pptp
      no ppp authentication PAP
      ppp authentication MSCHAPv2
    stm dos-prevention enable
    stm vlan-mobility disable
    stm strict-compliance enable
    stm fast-roaming disable
    stm sta-dos-prevention enable
    stm sta-dos-block-time 3600
    stm auth-failure-block-time 0
    stm coverage-hole-detection disable
    stm good-rssi-threshold 20
    stm poor-rssi-threshold 10
    stm hole-detection-interval 180
    stm good-sta-ageout 30
    stm idle-sta-ageout 90
    stm ap-inactivity-timeout 15
    mux-address 0.0.0.0
    adp discovery enable
    adp igmp-join enable
    adp igmp-vlan 0
    voip prioritization enable
    mgmt-role guest-provisioning
            description "This is Default Super User Role"
            permit local-userdb read write
    mgmt-role root
            permit super-user
    mgmt-user admin root b65b8ff25272bb5f9e17bea3f22d10e8560b34e4d81de262
    no database synchronize
    database synchronize rf-plan-data
    ip igmp
    ip router pim
    ads netad mode disable
    packet-capture-defaults tcp disable udp disable sysmsg disable other disable
    end
    #3600
  • 2.  RE: AP70s do not register to Controller 800! Help!!
    Posted Aug 29, 2012 01:21 PM
    ArubaOS version 2.4 is quite old and is not supported anymore. My suggestion would be to upgrade the controller first and then troubleshoot.
    Do you know what OS version are the APs running?
  • 3.  RE: AP70s do not register to Controller 800! Help!!
    Posted Aug 29, 2012 01:52 PM
    Since the controllers and aps are old, they are no longer under a support contract.  Is there somewhere I can look to get an updated OS for the device?  Also, since I cannot get into the APs, I cannot tell what version OS they are running. We are in a bit of a pickle with this so any assistance is welcomed.
  • 4.  RE: AP70s do not register to Controller 800! Help!!
    Posted Aug 29, 2012 07:46 PM
    Since you have a 800, I would combine two articles:
    First, to connect to the console on those APS:
    How do I use the SOE feature for the 2400 series controller? https://kb.arubanetworks.com/app/answers/detail/a_id/348
    Second to purge them:
    How do I restore an AP to factory default? https://kb.arubanetworks.com/app/answers/detail/a_id/160
