AP93 Support Aruba OS
  • 1.  AP93 Support Aruba OS
    Posted Feb 29, 2016 08:57 AM
    AP93 can support which Aruba OS version? how can i find all aruba AP support OS version? I find on this site http://www.arubanetworks.com/support-services/end-of-life/#AccessPoints what does TBD mean?
  • 2.  RE: AP93 Support Aruba OS
    Posted Feb 29, 2016 08:59 AM
    Means it hasn't been determined yet and works with current releases. Always check the release notes for any limitations.
    Sent from Nine
  • 3.  RE: AP93 Support Aruba OS
    Posted Feb 29, 2016 09:01 AM
    You are on the right page.  TBD means that we are considering end of lifing it.  You should not purchase any more of that part, instead you should be looking at the "Recommended Replacement Product", the AP-104
  • 4.  RE: AP93 Support Aruba OS
    Posted Feb 29, 2016 09:10 AM
    thanks ,but  i just know does the ap 93 can work on Aruba OS 6.4.X? I wan to konw ap 93  support  The latest  os version ?
  • 5.  RE: AP93 Support Aruba OS
    Posted Feb 29, 2016 09:19 AM
    6.4.x is the latest version and the AP93 works on that version.
  • 6.  RE: AP93 Support Aruba OS
    Posted Feb 29, 2016 09:24 AM
    ok thank you
  • 7.  RE: AP93 Support Aruba OS
    Posted Feb 29, 2016 09:23 AM
    TBD means "To Be Decided".
    In the case of ArubaOS 6.4.3, the guide describes AP-93.
    In the IAPs with version 6.4.2.6-4.1, the release note said: "Support for IAP-92/93 is reintroduced in Instant 6.4.0.3-4.1.0.1 and will continue in future 6.4.x.x-4.1.x.x releases."
    There are some limitations described in both guides.
  • 8.  RE: AP93 Support Aruba OS
    Posted Nov 21, 2018 04:02 AM
    Hi All,
    It's 2018 now and wondering what's the latest OS supported on AP-93.
    Currently using a Dell PowerConnect W-3200. Would updating the AP-93 firmware in Instant AP mode prevents it from working with the controller?
  • 9.  RE: AP93 Support Aruba OS
    Posted Nov 21, 2018 12:26 PM
    The last supported software versions for (I)AP-93 are 8.2 (AOS) and 4.1 (Instant).
  • 10.  RE: AP93 Support Aruba OS
    Posted Jan 30, 2019 11:28 PM
    Thank you for the reply.
    Does upgrading to 8.2 on ArubaOS requires a new license? Does it work with the current?
    Also, does updating AOS also updates the firmware on the AP-93?
  • 11.  RE: AP93 Support Aruba OS
    Posted Feb 02, 2019 08:22 PM
    Upgrading AOS does not require a new license.
    AP firmware is included in the AOS image. The APs will upgrade.
