ap93 turn off mobility
This thread has been viewed 24 times
  • 1.  ap93 turn off mobility
    Posted Jul 13, 2016 06:05 PM
    I have a bunch of aruba 93's 105's 92's, and a few controllers.
    I have one particular AP93 that is having an issue. It is not coming up in my aruba-master. I went on the serial consolse and reset it (running purge, save, reset).
    Now it does the login screen with a repeating message saying "turn off mobility".
    I can not log into via serial or the web interface using admin/admin.
    This is the only AP thats doing it from a batch of AP93's that all reset fine and came up on my controller. Any help?
  • 2.  RE: ap93 turn off mobility
    Posted Jul 13, 2016 06:12 PM
    Does the regulatory of the IAP-93 and the mobility controller match?
  • 3.  RE: ap93 turn off mobility
    Posted Jul 13, 2016 06:21 PM
    it is not an IAP and I'm  not sure what you're talking about with the "regulatory"
  • 4.  RE: ap93 turn off mobility
    Posted Jul 13, 2016 06:44 PM
    The only instance I know if that message is an IAP that was converted to a campus AP that does not match the regulatory domain of the target controller.  If you want, you can open a case with TAC to determine what could be going on here.
  • 5.  RE: ap93 turn off mobility
    Posted Jul 14, 2016 12:50 AM
    Or did someone try to convert this AP-93 to a IAP-93. I remember showing this behavior when someone tried this not successful conversion.
    Can you also erase the image in the AP and then reboot it?
    Clear os
    community.arubanetworks.com/t5/Wireless-Access/Tutorial-AP-Boot-Commands/td-p/91734
  • 6.  RE: ap93 turn off mobility
    Posted Jul 14, 2016 06:25 PM
    Hey there!
    I saw this solution in another thread but they neglected the space between the words and it didn't work. Thanks  a million :)
  • 7.  RE: ap93 turn off mobility
    Posted Oct 08, 2019 04:10 AM
    How do you solve it, please?
  • 8.  RE: ap93 turn off mobility
    Posted Jul 14, 2016 12:51 AM
    It should pull a firmware image from the controller then
