Ap93 user raoming issue
  • 1.  Ap93 user raoming issue
    Posted Jan 14, 2013 07:54 AM
    Dear All,
    i have A620 controller ( version 6.1.3.6) with 2 AP93 configured on it with WPA2 enterprise (AES) authentication.
    APs are setup as
    Name AP Group Status AP IP Outer AP IP AP Type Switch IP .bg Clients .bg Channel .bg HT Mode .a Clients .a Channel .a HT Mode IPSEC Actions
    AP1defaultup192.168.10.201N/A93192.168.10.20038HT-40mhz0  Disabled
    AP2defaultup192.168.10.203N/A93192.168.10.20004HT-40mhz0  Disabled
    correct me if i am wrong please , alot of noice on floor is it thats why poor signal quality and speed?
    i have already A200 controller with 2 AP running on it (old wifi network) i was just testing it out how it goes, would try to turn off old wifi on weekend and see the results on noise levels and signal power
    Client PHY
    a0
    g0
    b0
    a HT0
    g HT3
    a HT 40MHz0
    g HT 40MHz0
    SNR (dB)
    1
    11
    1015202530354045505560
    Speed (bps)
    1
    11
    06 M12 M24 M36 M54 M108 M450 M
    Goodput (bps)
    2
    To Client (bps)
    11
    From Client (bps)
     11
    My main problem is that sitting users close to AP2 they are still connecting to AP1 with very low signal quality and speed of 1mbps and wont connect to AP2 which is like 10 feet away ?
    can any body please guide me through how to sort this issue so i can do some testing on weekend?
    Kind regards,
    Abdul
  • 2.  RE: Ap93 user raoming issue
    Posted Jan 14, 2013 11:37 AM
    Hi!
    What is the reason that you are using channel 4 and channel 8?
    For the noise floor you should check your environment with the spectrum monitoring feature if you have valid rfprotect license. You may also check what devices are possible causing the interference - this can be a microwave oven, cordless phone, bluetooth devices etc. and where the AP's are placed.
    Btw. 10 feet does not seem to be too far, is this a test environment?
    What kind of devices do have roaming issues?
    The roaming is very client specific, however, you can set some parameters on the controller to provide better roaming.
    you can set the "validate-pmkid" in the dot1x profile
    you can also try "handoff-assist" in the rf profile or try to set the "local probe response treshold" in the advanced ssid profile.
    You may find detailed explanation in the ArubaOS User Guide regarding these features.
  • 3.  RE: Ap93 user raoming issue
    Posted Jan 14, 2013 01:03 PM
    Forgot to mention that you also need to make sure your client has up-to-date drivers. On some clients you can set the roaming aggressiveness (on Intel chipsets for example) you may check this, too.
  • 4.  RE: Ap93 user raoming issue
    Posted Jan 14, 2013 11:42 PM
    Dear Zshusveti,
    Thank you for your valuble reply, it didnt specify any channel thats why AP was selecting any avaiable channels but i did made some changes, i have set APs on Channel 1 and max EIRP to 15 as  i thought to check what allowed MAX EIRP for country code AE is .
    show ap allowed-max-EIRP ap-name ap1 country-code AE
    Channel  1   2   3   4   5   6   7   8   9   10  11  12  13  14  36  40  44  48  52  56 60  64  100  104  108  112  116  120  124  128  132  136  140  149  153  157  161  165
    b        16  15  14  14  13  13  13  13  13  13  14  14  15  *   *   *   *   *   *   *  *   *   *    *    *    *    *    *    *    *    *    *    *    *    *    *    *    *
    g/a      15  15  14  14  13  13  13  13  13  13  13  13  13  *   22  21  21  21  21  21 20  20  25   25   25   24   24   24   24   24   23   23   23   *    *    *    *    *
    HT 20    15  15  14  14  13  13  13  13  13  13  13  13  13  *   22  21  21  21  21  21 20  20  25   24   24   24   24   24   23   23   23   23   23   *    *    *    *    *
    HT 40    15  14  14  14  14  13  13  13  13  13  13  13  13  *   21  21  21  20  20  19 19  19  25   24   24   24   24   24   23   23   23   23   23
    Handoff-assist is on and set to value 50
    local prode response treshold is set to value 20
    i couldnt find the validate-pmkid in dot1x profile if possible can you give me command or till then i will try to firgure out how to enable it.
    first posit i mention i think the noise is too hight becasue of old A200 controller with two AP running and i can see them interfaring and showing those as roudge, which i can only turn off on week end only :( and run further tests which can i think resolve my signal issue ( please advice if iam correct)
    i was testing romaing issue on updated new wireless cards and both of those laptop dont support  802.11K feature and will not connect to AP2 no matter how far and on low signal i get even it drop the signal out.
    this is the problem as user is like 10 feet as you said is not too far should connect to AP2 (10 feet away) and is still connecting to AP1 and signal is very low.
    i have the license for spectrum and i will try to do as you advised.
  • 5.  RE: Ap93 user raoming issue
    Posted Jan 15, 2013 12:21 AM
    What should normaly be noise threshold as i have set mine to 0 -dBm
  • 6.  RE: Ap93 user raoming issue
    Posted Jan 15, 2013 03:46 AM
    First of all I would suggest you to let ARM manage the channel and tx power settings at least while you are troubleshooting the roaming issues.
    Validate PMKID can be found in All profiles - wireless lan - 802.1x authentication profile - choose the one which is assigned to your ap group and ssid - advanced tab (middle right section)
    First try to enable only the local probe response treshold feature and disable handoff assist. If the local probe response treshold does not help you may try the handoff assist.
    Also make sure the spectrum load balancing feature is disabled while local probe response treshold is enabled.
    You may also try to disable the low data rates in the SSID profile.
  • 7.  RE: Ap93 user raoming issue
    Posted Jan 15, 2013 06:23 AM
    Hi Again,
    i did as you advised, there was alot change in speed which was good, still client romaing didnt work.
    i turn off the AP1 and let the Ap2 on and try to see if a client can even connect to it, client was able to connect
    worst thing was that like 2 metters away i was connected with 2 bars and 300 mbps , if i go away like 5 meter gone cannot find the ssid ?
    may be location issue so removed it from there plugged at the same spot where AP2 was same issue.
    now what to do with this AP2 , shall i restore it to factory setting and re-set it up ?
    Abdul
  • 8.  RE: Ap93 user raoming issue
    Posted Jan 15, 2013 06:35 AM
    AP received configuration see below any idea guys ?
    BSSID6c:f3:7f:9e:1e:20
    LMS IP192.168.10.200
    Master IP192.168.10.200
    ModeAP Mode
    QBSS Probe ResponseAllow Access
    LED operating mode (11n APs only)normal
    Native VLAN ID1
    SAP MTU1500 bytes
    Heartbeat DSCP0
    High throughput enable (radio)Enabled
    Channel6-
    Beacon Period100 msec
    Non-Wi-Fi Interference Immunity2
    Beacon RegulateDisabled
    Transmit EIRP127 dBm
    Advertise 802.11d and 802.11h CapabilitiesEnabled
    TPC Power51 dBm
    Spectrum load balancingDisabled
    Spectrum Load balancing modechannel
    Spectrum load balancing update interval (sec)30 seconds
    Spectrum load balancing threshold (%)20 percent
    Advertized regulatory max EIRP0
    RX Sensitivity Tuning Based Channel Reusedisable
    RX Sensitivity Threshold0 -dBm
    Enable CSADisabled
    CSA Count4
    Reduce Cell Size (Rx Sensitivity)0 dB
    Management Frame Throttle interval1 sec
    Management Frame Throttle Limit20
    ARM/WIDS OverrideDisabled
    Protection for 802.11b ClientsEnabled
    Maximum Distance6450 meters
    Active ScanDisabled
    VoIP Aware ScanDisabled
    Power Save Aware ScanDisabled
    Video Aware ScanDisabled
    Load aware Scan Threshold1250000 Bps
    40 MHz intoleranceDisabled
    Honor 40 MHz intoleranceEnabled
    CSD overrideDisabled
    Simulatefalse
    Advertise 802.11K CapabilityDisabled
    Measurement Mode for Beacon Reportsbeacon-table
    Configure specific channel for Beacon RequestsDisabled
    Channel requested for Beacon Reports in 'A' band36
    Channel requested for Beacon Reports in 'BG' band1
    Time duration between consecutive Beacon Requests60 sec
    Time duration between consecutive Link Measurement Requests60 sec
    Time duration between consecutive Transmit Stream Measurement Requests90 sec
    Enable Handover Trigger featureDisabled
    Country CodeAE
    ESSIDRouseWlan
    Encryptionwpa2-aes
    WPA2 Pre-AuthDisabled
    DTIM Interval1 beacon periods
    802.11g Basic Rates11 12 18 24 36 48 54
    802.11g Transmit Rates2 11 12 18 24 36 48 54
    Station Ageout Time1000 sec
    Max Transmit Attempts8
    RTS Threshold2333 bytes
    Short PreambleEnabled
    Max Associations64
    Wireless Multimedia (WMM)Disabled
    Wireless Multimedia U-APSD (WMM-UAPSD) PowersaveDisabled
    WMM TSPEC Min Inactivity Interval0 msec
    DSCP mapping for WMM voice AC56
    DSCP mapping for WMM video AC40
    DSCP mapping for WMM best-effort AC24
    DSCP mapping for WMM background AC8
    Hide SSIDDisabled
    Deny_Broadcast ProbesDisabled
    Local Probe ResponseEnabled
    Local Probe Request Threshold (dB)20
    Disable Probe RetryDisabled
    Battery BoostDisabled
    Maximum Transmit Failures0
    BC/MC Rate OptimizationDisabled
    Rate Optimization for delivering EAPOL framesDisabled
    Strict Spectralink Voice Protocol (SVP)Disabled
    802.11g Beacon Ratedefault
    Advertise QBSS Load IEDisabled
    Temporal Diversity EnableDisabled
    High throughput enable (SSID)Enabled
    40 MHz channel usageEnabled
    Low-density Parity CheckDisabled
    MPDU AggregationEnabled
    Max transmitted A-MPDU size65535 bytes
    Max received A-MPDU size65535 bytes
    Min MPDU start spacing8 usec
    BA AMSDU EnableEnabled
    Supported MCS set0-15
    Short guard interval in 20 MHz modeDisabled
    Short guard interval in 40 MHz modeEnabled
    Maximum number of spatial streams usable for STBC transmission1
    Maximum number of spatial streams usable for STBC reception1
    VLAN1
    Forward modetunnel
    Dynamic Multicast Optimization (DMO)Disabled
    Band SteeringDisabled
    Steering Modebalance-bands
    Copyright (c) 2002-2012, Aruba Networks, Inc.
  • 9.  RE: Ap93 user raoming issue
    Posted Jan 15, 2013 07:00 AM
    What kind of devices are you using for testing?
    You should try the roaming with different devices like iOS device, Android, Windows laptop etc. Do you have the same issue with all of these?
    Have you tried to change the romaing aggressiveness on any of the clients?
    When you are 5 meter away from the AP you can not even see the SSID on the client? This sounds strange.
    If you want to reset the AP use the purgeenv command not the factory reset!
  • 10.  RE: Ap93 user raoming issue
    Posted Jan 15, 2013 07:09 AM
    I used , Dell , IBM & HP laptop with required thing enabled on wireless card  win xp and win 7,Iphone 5s , Samsung S2 , S3  HTC (all runing 4.0 andriod)
    same having signal issue with AP2 (i have took off the AP1)
    as for when all these devices connected to AP1 samsung devices were only who will drop out the connection while still connected to  AP1  as for HTC and laptops they work all good  and was not switching to AP 2 if near to AP2 and AP1 signal is low.
    ok i will try purge AP2 and see if fix any issues on this and get back to you.
  • 11.  RE: Ap93 user raoming issue
    Posted Jan 15, 2013 07:22 AM
    sorry forgot to add some thing , when 5 meet away i can see SSID and its connected  with only showign 2 bar on signal and if i go away like 10 meters its gone finish it comes and go with one bar and unable to connect.
    if i refresh like 10 times it shows up once only
  • 12.  RE: Ap93 user raoming issue
    Posted Jan 15, 2013 07:29 AM
    Did you have a chance to check the RF environment with a spectrum monitor AP?
  • 13.  RE: Ap93 user raoming issue
    Posted Jan 15, 2013 08:33 AM
    AP2 still low on signal , I did RF spectrum thing I seen to much noise but a lot of interference. do you think if interference there might be effecting the AP2 ?
    if so i will test this signal issue on week end when i turn off old wireless.
    ok user roaming problem is resolved i turn on the AP1 and went  right next to AP2 and i switch the client to AP2.
    Thanks for helping me with Roaming issue.
    will update this post when happeneds on weekend, also please advise you want me to do any other testing that can help me.
  • 14.  RE: Ap93 user raoming issue
    Posted Jan 15, 2013 08:36 AM
    Can you confirm that the roaming is solved now?
    What noise floor do you have? What kind of interfering devices you see in the spectrum analysis?
    You may run through this VRD: http://www.arubanetworks.com/wp-content/uploads/DG_Roaming.pdf - it can definitely help to further optimize your network for roaming.
  • 15.  RE: Ap93 user raoming issue
    Posted Jan 15, 2013 08:55 AM
    Yes the roaming issue has been resolved .
    AP1 -92 and AP2 -99 noise lvl.
    2 AP from my old wireless network and 2 very low near by company wireless network 1 AP each.
    sure i will check it out and update you
  • 16.  RE: Ap93 user raoming issue
    Posted Jan 15, 2013 09:10 AM
    -99 noise floor should not be an issue, it is quite good
  • 17.  RE: Ap93 user raoming issue
    Posted Jan 17, 2013 12:36 AM
    Hi Zshuveti,
    a question , as you know currently i am on G 2.4 ghz band and i would like to test out G 5ghz over the weekend to see if the AP2 signal approves, can you guide me how can i achive  that ?
    as i noticed where i have mounted AP 2  on false ceiling  near by there are like 3 Split roof AC mounted above the flase ceiling that might be killing AP2 strength so would like to test out 5 ghz  and see if that helps me out.
    Please advice.
    Many thanks.
    Abdul
  • 18.  RE: Ap93 user raoming issue
    Posted Jan 17, 2013 02:19 AM
    Really this AP2 is gonna push me off the cliff.
    i put the AP1 in the same position as in AP2 , it works all good  with same signal strength as in old location.
    i place AP2 in to AP1 fix location and it still same signal dies out after 10 meter.
    i was thinking it might be those air cons killing it but i dont think so as AP1 works great.
    really can some body help me with this AP2  as i see its on same policy group as AP2 so why ? could it be hardware fault ?
  • 19.  RE: Ap93 user raoming issue
    Posted Jan 17, 2013 05:49 AM
    update on AP2 signal issue , called up Aruba support team they looked in  run tests and stuff, end of the AP  hardware is faulty , they will replace it and lets see  ^_^
  • 20.  RE: Ap93 user raoming issue
    Posted Jan 17, 2013 06:38 AM
    Good to hear that the problem has been identified. I guess everything works for now, right?
