HI
At one of the sites, the customer is using AP93h, AP92 and AP93 with 650 controller.
As all the above mentioned APs have single radio and by default they are working on 2.4 GHz. As per the customer requirment we have to enable the 5Ghz.
I am trying to enable the 11a radio profile also tried the following commands on CLI
ap system-profile <nameofprofile>
rf-band "a"
But still the Aps are working on 2.4GHz and not switching the band.
currently the controller is running on 6.4
i have tried the above method on the other controllers which works perfectly fine but i am not sure what exactly the problem is or may be some limitation on 650 which i am not aware of.
Please let me know if some one ran into the same problem.
