AP93H on 6.5.4.0 heartbeat problems
  • 1.  AP93H on 6.5.4.0 heartbeat problems
    Posted Nov 27, 2017 06:22 AM
    Doing a bit of troubleshooting to try and resolve issues with APs going down... and I've found a large number of our AP93H units are flipping between controllers.
    We don't use any HA, each AP system profile has a backup controller and we rely on the AP to fail over if it loses heartbeat.
    The AP93H is doing this a lot. In each case it's just one AP that fails over out of multiple APs on the same Vlan/subnet and switch. The AP is not rebooting, they have the expected uptime. This issue appears to only be affected the AP93H.
    Anyone else seen this?
  • 2.  RE: AP93H on 6.5.4.0 heartbeat problems
    Posted Nov 27, 2017 07:25 AM
    I should add this isn't a problem that's new to 6.5.4.0 I found someone talking about this same issue back in 2015... and it was me.
  • 3.  RE: AP93H on 6.5.4.0 heartbeat problems
    Posted Nov 27, 2017 08:06 AM
    Hi!
    What is the failover reason listed when issuing show ap debug system-status on an AP that recently had the issue?
    Are they provisioned as RAPs or CAPs?
    Cheers,
  • 4.  RE: AP93H on 6.5.4.0 heartbeat problems
    Posted Nov 27, 2017 08:21 AM
    Hey... They're configured as CAPs.
    Here's the latest failover notice from the rebootstrap information:
    2017-11-26 23:07:21 Switching to LMS 144.32.64.34: Missed heartbeats: Last Sequence Generated=63251 Sent=63251 Rcvd=63240; eth Sent=5764883 Drop=0; gre Sent=5764883 Drop=0 First=1; ipsec Sent=0 Drop=0. Last Ctrl message: KEEPALIVE len=45 dest=144.32.64.36 tries=1 seq=150
    2017-11-26 23:13:32 Switching to primary LMS 144.32.64.36
    The switch has another 15 APs connected, none of which experienced a problem at this time, but have rebootstrapped at other points.
    I certainly haven't ruled out there being a network issue, but we don't see multiple APs rebootstrap at the same time (which is a sure sign of a network problem) and whilst we see a lot of AP93H do this, I don't believe I'm seeing it with any other model... Possibly the 130 series, but I don't have enough data points for those.
  • 5.  RE: AP93H on 6.5.4.0 heartbeat problems
    Posted Nov 28, 2017 08:30 AM
    Perhaps you could try to slightly increase the "Bootstrap threshold" in the AP system profile?
    Cheers,
