APAE Disconnect
  • 1.  APAE Disconnect
    Posted Feb 04, 2014 04:44 PM
    In the client trail-info, what does "APAE Disconnect" mean?
    Client Trail Info
    MAC                BSSID              ESSID        AP-name   VLAN  Deauth Reason                 Alert
    c4:62:ea:xx:xx:fe  00:0b:86:xx:xx:e8  osuwireless  krce-1-1  3296  STA has roamed to another AP  APAE Disconnect
    Deauth Reason
    Reason                            Timestamp
    STA has roamed to another AP      Feb  4 11:08:32
    Internal deauth                   Feb  4 10:35:52
    Response to EAP Challenge Failed  Feb  4 10:35:51
    Internal deauth                   Feb  4 09:22:49
    Internal deauth                   Feb  4 09:06:51
    STA has roamed to another AP      Feb  4 08:56:57
    Num Deauths:6
    Alerts
    Reason                            Timestamp
    APAE Disconnect                   Feb  4 11:10:56
    Unspecified Failure               Feb  4 10:35:17
    Num Alerts:8
    Mobility Trail
    BSSID              ESSID        AP-name   Timestamp
    00:0b:86:xx:xx:e8  osuwireless  krce-1-1  Feb  4 11:10:56
    00:0b:86:xx:xx:e8  osuwireless  krce-1-1  Feb  4 11:08:32
    9c:1c:12:xx:xx:30  osuwireless  krce-1-4  Feb  4 11:08:32
    9c:1c:12:xx:xx:30  osuwireless  krce-1-4  Feb  4 10:35:52
    9c:1c:12:xx:xx:30  osuwireless  krce-1-4  Feb  4 10:35:51
    9c:1c:12:xx:xx:30  osuwireless  krce-1-4  Feb  4 10:35:21
    9c:1c:12:xx:xx:20  attwifi      krce-1-4  Feb  4 10:35:17
    9c:1c:12:xx:xx:20  attwifi      krce-1-4  Feb  4 10:35:16
    9c:1c:12:xx:xx:20  attwifi      krce-1-4  Feb  4 10:35:10
    Num Mobility Trails:10
  • 2.  RE: APAE Disconnect
    Posted Feb 18, 2014 08:36 AM
    I may be way off base here, but this is my understanding after looking into it in my own environment...
    If a station associates to an 802.1x SSID but does not complete the EAPOL process within a timeout period (~60 seconds?), the controller deauths the station & logs it in the client's trail-info as an APAE disconnect.
    In my environment, I see this sometimes when a client is too far from an AP (walking across campus w/their phone in their pocket), or if a client's driver is quite old.
    If I'm completely wrong on this, Aruba folks, correct me and blank my post! :)
  • 3.  RE: APAE Disconnect
    Posted Nov 25, 2014 10:24 PM
    To confirm APAE Disconnect: Authenticator Port Access Entity Disconnect. It is a Dot1x Event.
    Authenticator PAE – The Authenticator PAE communicates with the Supplicant PAE, receiving identifying information from the Supplicant. Acting as a RADIUS client, the Authenticator PAE passes the Supplicant’s information to the Authentication Server, which decides whether the Supplicant can gain access to the port. If the Supplicant passes authentication, the Authenticator PAE grants it access to the port.
    Please also take note for the event(s) preceding that. In Ryan's original case in this topic, there was an "internal deauth"
     Internal Deauth is silent ageout of station. it removes the entry of the client from the APs tables.
    • This means - Without sending Deauth in the air.
    • This can happen for multiple reason like Max Tx Fail for one reason.
    Thx,
  • 4.  RE: APAE Disconnect
    Posted Nov 26, 2014 09:47 AM
    Hi, kc. In this case, however, the Internal Deauth was 35min prior and irrelevant I believe. More interesting is the client had associated to AP 1-4 and then 1-1 in the same second, which I assume was related to the APAE Disconnect.
  • 5.  RE: APAE Disconnect
    Posted Feb 18, 2015 12:10 AM
    Hi all,
    What is the solution for this?
    Just checking.
  • 6.  RE: APAE Disconnect
    Posted Feb 18, 2015 06:35 AM
    msaw,
    APAE disconnect is not necessarily something that needs a solution.  What do you mean?
  • 7.  RE: APAE Disconnect
    Posted Feb 18, 2015 08:34 AM
    Hi Colin,
    Is the a way to reduce or prevent APAE disconnect?
  • 8.  RE: APAE Disconnect
    Posted Feb 18, 2015 08:35 AM
    Msaw,
    I would say no. It is an internal cleanup process.
