Apboot during update
This thread has been viewed 26 times
  • 1.  Apboot during update
    Posted Sep 01, 2021 10:50 AM
    Looking to update our environment of controllers and access points, the below is just a simplicity of my question, thanks for any help!
    Say that you have a primary controller with ip (Switch IP) 1.1.1.1 a redundant secondary controller with ip (Standby IP) 2.2.2.2.
    We start by moving all access points from 2.2.2.2 to 1.1.1.1 with ap-move all, we then update our standby controller.
    When this is done we want to boot / move back and update all access points, we do this with apboot all, does this update and move them back to 2.2.2.2 (the other controller)?
    If we use ap-move all do the move / reboot to 2.2.2.2 and update?
    Can you use apboot on controller2 on five access points say in group A so they get on controller1 and update -
    and then from controller2 issue apboot ap-group A and only the remaining access points on controller2 will boot and update to controller1 (not the one already updated beforehand, these on controller1 will not reboot), correct - right?
  • 2.  RE: Apboot during update
    Posted Sep 09, 2021 04:37 AM
    I'm going to answer my own question regarding which controller i choses on apboot, it's the controller you have specified under your ap-group and then under ap-system-profile.
    Question remains though if it always reboot's when using ap-move or not?
    Grex Free
