last person joined: 10 hours ago
api-207
  • 1.  api-207
    Posted Feb 12, 2019 06:36 PM
    HI
    I APPRECIATE YOUR ADVICE,
    I WANT TO KNOW IF THIS MODEL API 207 CAN BE ADDED TO A GROUP OF APIN 0205.
    THE VIRTUAL CONTROLLER VERSION IS 6.4.2.6-4
    THANK YOU
  • 2.  RE: api-207
    Posted Feb 12, 2019 07:27 PM
    According to the datasheet for the IAP-207 here:  https://www.arubanetworks.com/assets/ds/DS_AP207Series.pdf the minimum version for the IAP-207 on Instant is 4.3.1.0, so you would need to upgrade the 205s to the version of code in this folder here first:  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/EntryId/24588/Default.aspx before adding the IAP 207s
