Hi each time when i do a api call i need a token .
so my requirement is to call api without using token
or if i generate that token then its never going to expire
can any one help me out
What language do you are using ?
the best pratice is to use client_id and client_secret and call api to generate token
you can also generate a token with very long life (like one year...)
Hi i am just using Curl command to execute api call.
Can you tell me the way how to generate token for very long
When, you create the client_id/client_secret, you can configure the Access Token Lifetime
but if you look the api/oauth API call, with the client_id and client_secret, generate access token
