Developer
  • 1.  API Gateway - Tokens and Refresh
    Posted Jul 02, 2024 03:16 AM
    Evening
    Hope this makes sense - I'm trying to make a simple method of managing visitor wireless credentials, utilising a Microsoft Form and Power Automate.
    I've written the flow and it works a treat, but I'm butting up against the 2hr limit on tokens and I'm really not sure how to handle this?
    Hoping for some advice on the best way to deal with this, as the flow is stateless (within reason) and it is difficult to have logic renewing the token every couple of hours that the main flow can use when somebody requests a visitor password.
    Any advice and pointers on this are welcome
    Cheers
  • 2.  RE: API Gateway - Tokens and Refresh
    Posted Jul 03, 2024 10:09 AM
    Unsure if it works with Power Automate (not familiar with that), if it's made for automation and API calls, probably yes. You can check here how you can use access tokens and refresh tokens to keep your access token valid and periodically automatically renew it with the renew token.
  • 3.  RE: API Gateway - Tokens and Refresh
    Posted Jul 04, 2024 02:06 AM
    You need to store also refresh_token and use this token for get a new access_token
    You can look : https://github.com/PowerAruba/PowerArubaCL/blob/master/PowerArubaCL/Private/Token.ps1#L16
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
