Developer
  • 1.  API X-CSRF-Token
    Posted Mar 18, 2024 07:44 AM
    AOS 8.10.0.10 Conductor and clusters
    I'm not a programmer but use the API to do a few tasks. I noticed that here https://www.arubanetworks.com/techdocs/ArubaOS_87_Web_Help/Content/nbapiguide/prerequisites.htm it says:
    "Starting from ArubaOS 8.7.0.0, UIDARUBA is deprecated. The X-CSRF-Token will be used in the header. The UIDARUBA is still available for backward compatibility with older ArubaOS firmware versions."
    I have always used UIDARUBA up til now, but thought I should start updating my scripts to use X-CSRF-Token. I was hoping I could just parse X-CSRF-Token from the login request (instead of UIDARUBA) and then add that to the header of my next request instead of the UIDARUBA token, but I keep getting 401 unauthorised.
    I seem to be getting the token itself fine, but then my next request fails:
                url = f"https://{mc}:4343/v1/configuration/object/reload"
                body = {
                    "force": True
                querystring = {"config_path": "/md"}   # UIDARUBA deprecated (removed from querystring) , switched to X-CSRF-Token 18/03/2024
                headers = {
                    "Content-Type": "application/json",
                    "Accept" : "application/json",
                    "Cookie" : f"SESSION={uid}",
                    "X-CSRF-Token" : f"{uid}"
                response = requests.request("POST", url, json=body, headers=headers, verify=False, params=querystring)
     What am I doing wrong here? I'm also not really sure what "Cookie" does but I've always included it, I must have got it from some documentation at some point. It was previously set to the UIDARUBA, but now 'uid' is the X-CSRF-Token.
  • 2.  RE: API X-CSRF-Token
    Posted Mar 18, 2024 09:37 AM
    Hi cauliflower
    I always use uidaruba....
    do you have check the log ? or output of error request ?
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: API X-CSRF-Token
    Posted Mar 18, 2024 02:10 PM
    In the logs I see:
    Mar 18 10:30:01 2024  httpd[32483]: SID validation failed for API opcode:/v1/configuration/object/reload, sid:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    Mar 18 10:30:01 2024  httpd[32483]: SID Validation failed POST URI:/v1/configuration/object/reload
    I'm not sure what SID is
  • 4.  RE: API X-CSRF-Token
    Posted Mar 19, 2024 06:51 AM
    Edited by Herman Robers Mar 25, 2024 08:55 AM
    This is what works for me... on the login, I get the following json-response (redacted):
    {'_global_result': {'status': '0', 'status_str': "You've logged in successfully.", 'UIDARUBA': 'ZTc1Njredacted1', 'X-CSRF-Token': 'NzhiM2redacted2'}}
    Then in the follow-up calls, I put this in the header:
    {'X-CSRF-Token': 'NzhiM2redacted2'}
    The Cookies:
    {'SESSION': 'ZTc1Njredacted1'}
    And in addition, I use the cookie function to collect/store/cache and send cookies that were received earlier.
    I think SID is session ID, which seems to sit in the cookies. But most important from your example is that the SESSION cookie and X-CSRF-Token are different values, which also make sense for a CSRF mechanism.
  • 5.  RE: API X-CSRF-Token
    Posted Mar 20, 2024 11:43 AM
    Thanks Herman,
    So previously I would just obtain a UIDARUBA using login and it looks like this is what was also set as the SESSION cookie value in the headers.  So how do I obtain a different value to use as the SESSION cookie?
    What are the implications of continuing to use UIDARUBA in the way I am? Is it considered insecure now?
    And will the UIDARUBA method disappear at some point?
    Apologies for the many questions, as I say, I'm not a programmer so some of this is new to me
    Guy
  • 6.  RE: API X-CSRF-Token
    Posted Mar 25, 2024 09:23 AM
    I see I made a mistake in the example I used before... So the 'X-CSRF-Token' goes as a header, the UIDARUBA goes as the SESSION Cookie; but it is also received as a 'Set-Cookie' on the request, so if you use a cookie-jar or so, you should just use the X-CSRF-Token.
    As far as I know, it you don't use the X-CSRF-Token, it will just not work, so it's required for accessing the API modern versions of ArubaOS.
  • 7.  RE: API X-CSRF-Token
    Posted Mar 21, 2024 07:27 AM
    There is a typo on Aruba 8.12 API guide, it is say
    X-CSRFToken
