I have purchased from a company which went bancrupt one APIN0205. I do NOT have a controller, and I want to use it as a standalone AP.
I did a factory reset, the device gets an IP from my DHCP server, and I can ping it, but I cannot enter in.
I made a console cable, and I have control.
I have done the follwoing on the command line for a factory reset:
factory_reset
purgeenv
save
boot
Now the AP boots up, gets and IP and netmask from my DHCP server and it continues to search for the controller using ADP. After a while, it gives up and reboots.
Does anyone know how to conifgure it on the console level to have the device not to look for the controller? In other words, how can I enter its GUI, without the controller?
I looked in a lot of communities but it was not mentioned anywhere this procedure.
Thanks for replying.
