APIN0225 - how to get in?
This thread has been viewed 26 times
  • 1.  APIN0225 - how to get in?
    Posted Feb 20, 2024 03:26 AM
    HI,
    I need your help. I have 3x Aruba APs APIN0225 and I can't log in to them neither via serial port nor via wireless. I have did reset them to factory settings via command line, but it did not change anything. I must be doing something wrong, but I don't what it is.
    Can anyone advise what should I do?
  • 2.  RE: APIN0225 - how to get in?
    Posted Feb 20, 2024 03:27 AM
    Do you have AP-225 on the sticker on the back? Or IAP-225-RW (or -US, -JP)? Both have APIN0225, but AP-225 needs an external controller, the IAP-225-xx can be operated without a controller.
  • 3.  RE: APIN0225 - how to get in?
    Posted Feb 21, 2024 12:20 PM
    Thanks for your response.
    The only thing written there is: Model: APN0225. Please see below. I think I need a controller, but whole idea was to get rid of licesnses - I currently have meraki...
    Aruba Networks AP-225 APIN0225 PoE WiFi 802.11ac 5GHz Wireless - Access Point _ .jpg
  • 4.  RE: APIN0225 - how to get in?
    Posted Feb 21, 2024 12:42 PM
    That model number, by default, must be managed by a controller.
    If you have access to an Aruba Controller, the controller hosts a process that can convert these APs to IAPs. [note: 225 max supported is 8.6 for IAP]
    Using the Controller for conversion or management are the only supported methods.
    If my post was useful, please Accept Solution and Give Kudos.
    Zak Chalupka
    Principal Engineer - HPE Aruba
    ACDX | ACMP | ACSP | ACCP
    wifizak@hpe.com
    Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
  • 5.  RE: APIN0225 - how to get in?
    Posted Feb 21, 2024 01:52 PM
    Thanks for this information. I have no access to the controller so if I buy one ie on eBay, I would have to purchase a licenses for the controller and the APs?
     Thanks in advance.
  • 6.  RE: APIN0225 - how to get in?
    Posted Feb 21, 2024 04:51 PM
    Yes, you will need both a Controller and Licensing for that initial Control Plane tunnel to be built.
    Or look for the IAP specific AP in the 225 Series. Aruba now has a unified OS that supports both Controller and Controllerless Modes, but that was released post AP-225.
    If you have a local HPE Aruba Partner, I would talk to them about your options there.
    Zak Chalupka
    wifizak@hpe.com
  • 7.  RE: APIN0225 - how to get in?
    Posted Feb 22, 2024 03:46 AM
    There are stickers removed from the area where the sticker with SN and MAC is attached, which is not a good sign (hiding information). Unsure where you got this AP, but it may be best to return it and get an IAP-225 (or other AP that is IAP or has a -RW, -JP or -US extension depending on where you live) model if you want to get rid of licenses.
  • 8.  RE: APIN0225 - how to get in?
    Posted Feb 22, 2024 10:08 AM
    Try this.
    https://www.reddit.com/r/ArubaNetworks/comments/grunb4/comment/g6p7z2j/
    As for licenses, contact TAC to see if there is support for this model or if they would be able to provide evaluation licenses [ Usually 90 days ] - Highly unlikely if the product is EOS or EOL.
    /AJ
