APIN207 bootup time
  • 1.  APIN207 bootup time
    Posted May 23, 2019 07:00 AM
    APBoot 2.1.4.11 (build 59208)
    Built: 2017-04-13 at 18:41:18
    Model: AP-207
    CPU:   BCM47452 revision: 3
    Clock: 900 MHz, DDR rate: 533 MHz
    DRAM:  255 MiB
    Flash: Detected W25Q32FV: total 4 MiB
    NAND:  Detected a Mxic NAND flash: total 128 MiB
    PCIe0: RC, link up
           dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
           00  00  14e4  aa31 00002   02 00000004 00000000 00000004 00000000
    Power: POE
    Net:   eth0
    Radio: bcm43570#0, bcm47452#1
    Reset: cold
    FIPS:  passed
    Hit <Enter> to stop autoboot:  0
    Booting OS partition 1
    Checking image @ 0x2000000
    Copying image from 0x04100000
    14 seconds
    Image is signed; verifying checksum... passed
    SHA2 Signature available
    Signer Cert OK
    Policy Cert OK
    RSA signature verified using SHA2.
    37 seconds
    Uncompressing... done
    50 seconds
    [    0.000000]
    [    0.000000] Aruba Networks
    [    0.000000] ArubaOS Version 6.5.4.0-6.5.4.0 (build 60834 / label #60834)
    [    0.000000] Built by p4build@pr-hpn-build05 on 2017-08-04 at 20:47:54 UTC (gcc version 4.7.2)
    [    0.000000]
    [    0.000000] Flash variant: default
    [    0.000000] MPCORE found at 18310000, SCTLR 0x10c53c7f ACTLR 0x00006040 CPSR 0x600001d3 SPSR 0x000001d3 PRRR 0xff0a81a8 NMRR 0x40e040e0
    [    0.000000] Memory: 256MB = 256MB total
    [    0.000000] Memory: 243432k/243432k available, 18712k reserved, 0K highmem
    [    0.000000] External imprecise Data abort at addr=0xd7fd28a7, fsr=0xc06 ignored.
    [    0.000000] Found ST compatible serial flash with 64 64KB blocks; total size 4MB
    [    0.000000] MPCORE Global Timer Clock 35226Hz
    [    0.046000] CCA UART Clock Config: Sel=1 Ovr=1 Div=88
    [    0.046000] CCA UART Clock rate 40000000Hz
    [    0.048000] ACP (Accelerator Coherence Port) disabled
    [    8.618000] PCI: no core
    [    8.820000] PCI: scanning bus 0
    [    8.820000] PCI: Fixing up bus 0
    [    9.074000] PCIE1 link=1
    [    9.074000] PCIE1 switching to GEN2
    [    9.324000] PCIE1 link=1
    [    9.324000] PCI: Fixing up bus 0
    [    9.326000] PCI: Fixing up bus 1
    [    9.326000] pci 0001:00:00.0: BAR 8: assigned [mem 0x10000000-0x105fffff]
    [    9.326000] pci 0001:01:00.0: BAR 2: assigned [mem 0x10000000-0x103fffff 64bit]
    [    9.326000] pci 0001:01:00.0: BAR 2: set to [mem 0x10000000-0x103fffff 64bit] (PCI address [0x10000000-0x103fffff]
    [    9.326000] pci 0001:01:00.0: BAR 0: assigned [mem 0x10400000-0x10407fff 64bit]
    [    9.326000] pci 0001:01:00.0: BAR 0: set to [mem 0x10400000-0x10407fff 64bit] (PCI address [0x10400000-0x10407fff]
    [    9.382000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    9.494000] Creating 1 MTD partitions on "bcmsflash":
    [    9.496000] 0x000000000000-0x000000400000 : "nor"
    [    9.498000] Northstar brcmnand NAND Flash Controller driver, Version 0.1 (c) Broadcom Inc. 2012
    [    9.500000] NAND device: Manufacturer ID: 0xc2, Chip ID: 0xf1 (MXIC NAND 128MiB 3,3V 8-bit)
    [    9.502000] Scanning device for bad blocks
    [    9.954000] Creating 3 MTD partitions on "brcmnand":
    [    9.956000] 0x000000000000-0x000002000000 : "aos0"
    [    9.958000] 0x000002000000-0x000004000000 : "aos1"
    [    9.960000] 0x000004000000-0x000008000000 : "ubifs"
    [   11.334000] i2c-springbank: using remapped base d09d0060
    [   11.336000] mpcore_wdt mpcore_wdt: enabling watchdog.
    [   11.338000] ramzswap: num_devices not specified. Using default: 1
    [   11.340000] ramzswap: Creating 1 devices ...
    [   11.462000]
    [   11.462000] Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    [   11.466000] Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    [   11.488000] Starting Kernel DES KAT ...Completed Kernel DES KAT
    [   11.492000] Starting Kernel AES KAT ...Completed Kernel AES KAT
    [   11.494000]
    [   11.496000] Starting Kernel AESGCM KAT ...Completed Kernel AESGCM KAT
    Thu Jan  1 00:00:00 PST 1970
    Domain Name: SetMeUp.arubanetworks.com
    Current OEM Name : Aruba Networks
    Disabling ipv6 for devices by default
    AP-type has_ble_support: BRCM_ONBOARD.
    IPv6 capability is supported for devices
    No panic info available
    Enabling bsa_server via nanny
    Enabling ble_daemon and ble_relay via nanny
    Backup ENV.
    Enter non-FIPS mode
    Cfg len is 2904
    Starting watchdog process...
    Loading configuration file of length 2904...
    wifi uplink not present...
    Terminal access enabled...
    Valid SSID detected...
    touching file /tmp/ip_mode_0
    Enabling DHCPv6 ... IP mode is v4-only ...
    [   25.138000] ADDRCONF(NETDEV_UP): bond0: link is not ready
    do ethtool autoneg on for bond0
    eth0 uplink enabled
    SIOCGIFFLAGS: No such device
    Cannot get device settings: No such device
    Cannot get wake-on-lan settings: No such device
    Cannot get message level: No such device
    Cannot get link status: No such device
    eth1 admin down
    init usb modem ...
    springbank: Copying BT modules to /tmp
    USB is not supported on this model
    Ethernet uplink not active yet
    [   30.148000] bond0: link up (1000FD)
    [   30.150000] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    disable auto topology rules
    Starting up in standalone mode
    copying bootuplog ...
    [   31.752000] AP xml model 96, num_radios 2 (jiffies 15876)
    [   31.754000] apType 96 hw_opmode 0
    [   31.756000] radio 0: band 1 ant 0 max_ssid 16
    [   31.758000] radio 1: band 0 ant 0 max_ssid 16
    [   31.760000] init_asap_mod: installation:0
    [   31.762000] election init: rand=16 HZ=500
    [   31.764000] IAP client match init
    set device anul0 mtu to 2000
    notify asap_mod 3g no present...
    notify asap standalone ap...
    apdot1x authentication is not enabled
    LLDP not sent yet, DHCP is waiting
    Starting DHCP
    Got all network params from APboot env. Skipping DHCP
    10.0.1.249 255.255.255.0 10.0.1.251
    ADP is disabled by uap_controller_less
    Compressing all files in the /etc/httpd directory...
    [   36.768000] ip_time_handler: ignore uplink port state, prefer master 0- standalone 1- wifi uplink 0- 3g uplink 0- enforce eth0 0
    [   36.770000] ip_time_handler: Got ip and packets on bond0 Started master election 2-0, rand 20
    Done.
    Starting Webserver
    bind: Transport endpoint is not connected
    Launching NTP Client on pool.ntp.org
    [   53.404000] wifi0: AP type AP-207, radio 0, max_bssids 16
    [   53.504000] PCI: Enabling device 0001:01:00.0 (0140 -> 0142)
    [   53.562000] wifi1: AP type AP-207, radio 1, max_bssids 16
    springbank: Insmod BT modules
    [   54.218000] usbcore: registered new interface driver usbfs
    [   54.220000] usbcore: registered new interface driver hub
    [   54.222000] usbcore: registered new device driver usb
    [   54.238000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [   54.244000] ehci_hcd 0000:00:04.1: EHCI Host Controller
    [   54.246000] ehci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 1
    [   54.270000] ehci_hcd 0000:00:04.1: irq 36, io mem 0x18004000
    [   54.280000] ehci_hcd 0000:00:04.1: USB 0.0 started, EHCI 1.00
    [   54.282000] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [   54.284000] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   54.286000] usb usb1: Product: EHCI Host Controller
    [   54.288000] usb usb1: Manufacturer: Linux 2.6.35 ehci_hcd
    [   54.290000] usb usb1: SerialNumber: 0000:00:04.1
    [   54.294000] hub 1-0:1.0: USB hub found
    [   54.296000] hub 1-0:1.0: 2 ports detected
    [   54.312000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    [   54.314000] ohci_hcd 0000:00:04.0: OHCI Host Controller
    [   54.316000] ohci_hcd 0000:00:04.0: new USB bus registered, assigned bus number 2
    [   54.318000] ohci_hcd 0000:00:04.0: irq 36, io mem 0x1800d000
    [   54.376000] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
    [   54.378000] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   54.380000] usb usb2: Product: OHCI Host Controller
    [   54.382000] usb usb2: Manufacturer: Linux 2.6.35 ohci_hcd
    [   54.384000] usb usb2: SerialNumber: 0000:00:04.0
    [   54.388000] hub 2-0:1.0: USB hub found
    [   54.390000] hub 2-0:1.0: 2 ports detected
    [   54.408000] usbcore: registered new interface driver btusb
    [   54.830000] usb 2-1: new full speed USB device using ohci_hcd and address 2
    [   54.980000] usb 2-1: New USB device found, idVendor=0a5c, idProduct=2045
    [   54.982000] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [   54.984000] usb 2-1: Product: BCM2045A0
    [   54.986000] usb 2-1: Manufacturer: Broadcom Corp
    [   54.988000] usb 2-1: SerialNumber: 000000000000
    AP rebooted caused by cold HW reset(power loss)
    shutting down watchdog process (nanny will restart it)...
            <<<<<       Welcome to the Access Point     >>>>>
    Completed SW FIPS KAT test
    User: [   86.834000] i am master now
    [   86.836000] (08:01:18) !!! Init ---> Master
    [   86.838000] asap_send_elected_master: sent successfully
    2 minutes 25 seconds
    Wireless network available after 2 minutes and 45 seconds.
    We're going to use this AP in a standalone system, is there any way to reduce this boot time?
    Attachment(s)
    txt
    AP207log.txt   9 KB 1 version
  • 2.  RE: APIN207 bootup time
    MVP EXPERT
    Posted May 23, 2019 07:21 AM
    Why do you need a faster boot time?
  • 3.  RE: APIN207 bootup time
    Posted May 23, 2019 08:21 AM
    My PC with software is ready in less than 90 seconds and my wireless client is ready in 40 second.
    PC and AP are turned on at the same time so now is necessary to wait 3 minutes before being able to start to work with the equipment.
  • 4.  RE: APIN207 bootup time
    MVP EXPERT
    Posted May 23, 2019 08:34 AM
    I doubt there is much you can do to increase the AP boot time (if its even possible as its pretty much non-configurable). Are you working in an environment where the additional 2 minutes to boot is critical? Is the CAC timer running on the 5Ghz radio as well an issue?
  • 5.  RE: APIN207 bootup time
    Posted May 23, 2019 09:17 AM
    I don't know if it's possible but for example maybe just skipping image signature verification, reduce timeout in master election, DHCP timeout, DFS timer.
    As we work in a fixed and controlled enviroment there'are some useless step that maybe takes 1 minute all togeter.
  • 6.  RE: APIN207 bootup time
    Posted May 24, 2019 04:26 AM
    Have you converted your AP to standalone mode? If it is a single AP that may skip the master election process and save some time.
    From the logs, it looks like the AP has a fixed static IP already so there should not be DHCP timeouts. If you see delays on the 5GHz radio because of DFS waits, manually limit the radio to select non-DFS channels only (36-48) might take that component out, but the 2.4GHz radio should be enabled immediately.
    The image verification is important for the AP security and is bound by the CPU capacity of the AP which is considered an entry level AP in the Aruba product line. A higher end AP will boot faster in this case.
