APIN215 setup and Mac Authentication setup
  • 1.  APIN215 setup and Mac Authentication setup
    Posted Mar 17, 2015 11:04 AM
    Was looking to see if anyone had any suggestions on best practice setup on the instant wireless devices. Looking to lock down our office wireless access with the new device and seeing if anyone had any suggestions.  Mac authentication is one option we are looking at but the feature won't seem to enable.
  • 2.  RE: APIN215 setup and Mac Authentication setup
    Posted Mar 17, 2015 11:27 AM
    It is available, you need to select Security level as "Personal" then select MAC authentication enable.
    For your ref :
  • 3.  RE: APIN215 setup and Mac Authentication setup
    Posted Mar 17, 2015 11:31 AM
    Please ignore the prev post.
    Please select security level as "Open" and then select MAC authentication enabled.
    For your ref :
    Please feel free for any further help on this.
  • 4.  RE: APIN215 setup and Mac Authentication setup
    Posted Mar 17, 2015 12:28 PM
    Thanks Venu,
    When I got to the new network and choose securirty, it still shows MAC Authentication as disable but I hit edit it matches the screen shot that you sent me.  Also, what user to I add in?  I created myslef as a user, is that the correct thing to do?
    Thanks again
  • 5.  RE: APIN215 setup and Mac Authentication setup
    Posted Mar 17, 2015 12:53 PM
    HI,
    You have to enter the client MAC address as username and password in the local database as shown bellow,
    1. Click on Internal server (USer 1)
    2. Enter the MAC address of all those Clients to whom you want to allow (username and password should be same)
    Hope got the clarity.
  • 6.  RE: APIN215 setup and Mac Authentication setup
    Posted Mar 17, 2015 02:01 PM
    Thanks Venu,
    Just to clarify:
    I just need to add a new user.  In the userame field and password field I just need to enter in the Mac address of the device in both fields.  Is that correct?
  • 7.  RE: APIN215 setup and Mac Authentication setup
    Posted Mar 17, 2015 02:30 PM
    Yes My friend,
    Username and Password should be the MAC address of the client you want to allow.
  • 8.  RE: APIN215 setup and Mac Authentication setup
    Posted Mar 18, 2015 08:42 AM
    Thanks All,
    That did it.
    Another question though
    How do I assign static IP addresses to our devices?
  • 9.  RE: APIN215 setup and Mac Authentication setup
    Posted Mar 18, 2015 08:56 AM
    I don't believe the IAP has the ability to assign a static IP address. You would need to use a DHCP Helper which has this function.
    _ELiasz
