apple and android pulling 2 adress
  • 1.  apple and android pulling 2 adress
    Posted Jan 22, 2015 02:13 PM
    the apple device or android will still utilize the last ip address it attached to most likely the users home address 10.0.0 or 192. x
    The issue is it is using up address in a scope that is in my dmz on the 10 network ( don't yell at me some idiot used it as my dmz 10 years ago long before I worked here) I will be moving it asap. but for now, is there anything I can do to prevent this from happening
    (psd-master01) #show  user | include  10:1c:0c:2a:2a:1b
    10.0.0.10       10:1c:0c:2a:2a:1b                             psd-guest-logon    00:00:01                    AP-RM-211.Floor 1.100.GHH                  Wireless  psd-open/d8:c7:c8:f7:39:28/a-HT    psd-open    tunnel        iPad
    10.50.146.61    10:1c:0c:2a:2a:1b                             psd-guest-logon    00:00:01                    AP-RM-211.Floor 1.100.GHH              Wireless  psd-open/d8:c7:c8:f7:39:28/a-HT    psd-open    tunnel        iPad
    (psd-master01) #show  user | include  84:38:35:97:a5:59
    10.10.129.18    84:38:35:97:a5:59  84383597a559               psd-authenticated  00:01:34    MAC             ESC_SWITCH_ON_BENCH                        Wireless  psd-secure/ac:a3:1e:9a:3d:11/a-HT   psd-secure  tunnel        iPhone
    172.24.25.144   84:38:35:97:a5:59  84383597a559               psd-authenticated  00:01:34    MAC             ESC_SWITCH_ON_BENCH                     Wireless  psd-secure/ac:a3:1e:9a:3d:11/a-HT  psd-secure  tunnel        iPhone
  • 2.  RE: apple and android pulling 2 adress
    Posted Jan 22, 2015 02:14 PM
    If you are not using the 192 space, you can add a deny rule for that subnet to the validuser acl.
    Tim
  • 3.  RE: apple and android pulling 2 adress
    Posted Jan 22, 2015 02:17 PM
    Try that dosnt work
  • 4.  RE: apple and android pulling 2 adress
    Posted Jan 22, 2015 02:18 PM
    Tried that dosn't work
  • 5.  RE: apple and android pulling 2 adress
    Posted Jan 22, 2015 02:22 PM
    Do you have enforce-dhcp enabled in your AAA profile?
  • 6.  RE: apple and android pulling 2 adress
    Posted Jan 22, 2015 02:23 PM
    Edit: Cappalli already suggested that
  • 7.  RE: apple and android pulling 2 adress
    Posted Jan 22, 2015 09:00 PM
    Add the segments you want to allow on the controller to the valid user ACL. Search for valid user on the community.
  • 8.  RE: apple and android pulling 2 adress
    Posted Jan 22, 2015 09:04 PM
    All other segments will be denied
