Apple IOS Issue
  • 1.  Apple IOS Issue
    Posted Nov 20, 2017 11:37 AM
    We have a fairly new IAP 305 cluster (v6.5.4.2).  We have an issue where particular iPhones and MAC computers are being connected to the corporate SSID for about 2-3 seconds and then it completely disconnects.  Not happening with all devices.
  • 2.  RE: Apple IOS Issue
    Posted Nov 20, 2017 01:46 PM
    How often?
  • 3.  RE: Apple IOS Issue
    Posted Nov 20, 2017 02:39 PM
    most of the time.. about 8/10 times if the device ever decides to stay connected.
  • 4.  RE: Apple IOS Issue
    Posted Nov 20, 2017 04:47 PM
    What is your transmit power range for your access points and are you filtering broadcasts?
  • 5.  RE: Apple IOS Issue
    Posted Nov 20, 2017 04:51 PM
    min 12 /max 15 (I tweaked this last week when ppl were complaining of poor coverage)  that seemed to fix that issue
    broadcast filtering is disabled
  • 6.  RE: Apple IOS Issue
    Posted Nov 20, 2017 04:54 PM
    Why is broadcast filtering disabled?  Broadcasts are the #1 enemy of reliable wireless connectivity..
  • 7.  RE: Apple IOS Issue
    Posted Nov 20, 2017 04:56 PM
    isnt that default setting?  what should I set it to?
  • 8.  RE: Apple IOS Issue
    Posted Nov 20, 2017 04:58 PM
    It is not the default setting.  In the SSID under advanced, you should set broadcast filtering to ARP.  Do this for all of your SSIDs.
  • 9.  RE: Apple IOS Issue
    Posted Nov 20, 2017 05:07 PM
    didnt fix the issue
  • 10.  RE: Apple IOS Issue
    Posted Nov 20, 2017 05:12 PM
    How far apart are your access points?  That maximum transmit power is too low you should try a max and min of 18 unless you have very good density. Do you also have 80mhz channels enabled (E) after the channel?  If yes, you need to disable 80mhz channels in the ARM profile.  80 mhz channels can cause a decent amount of interference in a dense environment.
    Please read this:  http://community.arubanetworks.com/t5/Technology-Blog/Removing-the-Bottleneck-in-Wireless/ba-p/77978
  • 11.  RE: Apple IOS Issue
    Posted Nov 21, 2017 09:15 AM
    AP's are about 50-60 feet apart.
    Max and Min 18?
    80mhz channels enabled (E) after the channel?? how do I check that? Im using the default setting most-likely.
  • 12.  RE: Apple IOS Issue
    Posted Nov 21, 2017 09:49 AM
    Are you using the GUI or the CLI?
    You should be able to see what channels access points are using from the access points page.
  • 13.  RE: Apple IOS Issue
    Posted Nov 21, 2017 12:35 PM
  • 14.  RE: Apple IOS Issue
    Posted Nov 21, 2017 01:21 PM
    Okay.  You should go to RF> ARM and Uncheck 80mhz channels.  80 mhz channels is not helping your issue.
    While you are doing that, please look at this:  http://community.arubanetworks.com/t5/Technology-Blog/Removing-the-Bottleneck-in-Wireless/ba-p/77978
  • 15.  RE: Apple IOS Issue
    Posted Nov 21, 2017 03:30 PM
    OK
    Also, I have client match enabled.  Should I disable?
  • 16.  RE: Apple IOS Issue
    Posted Nov 21, 2017 05:06 PM
    No.
  • 17.  RE: Apple IOS Issue
    Posted Nov 21, 2017 05:18 PM
    I opened a ticket with TAC and they are not sure of the issue.  They need to evaluate some logs.
  • 18.  RE: Apple IOS Issue
  • 19.  RE: Apple IOS Issue
    Posted Nov 27, 2017 09:36 AM
    ill take a look
