Apple iOS Wispr and Captive Portal
  • 1.  Apple iOS Wispr and Captive Portal
    Posted Apr 30, 2014 12:39 PM
    We have a 7210 controller with several AP225 for our campus deployment. When i tested the guest captive portal setup on an Andriod, the guest login page is pulled automatically once they connect to the Guest SSID. They did not have to open a browser. On the other hand, on an iOS device, we have to go manually open the browser to get the guest captive portal login page to open. Is there a way to get iOS devices to open the guest captive portal page automally when they connect tot he Guest SSID?
    Chan
    #AP225
    #7210
  • 2.  RE: Apple iOS Wispr and Captive Portal
    Posted Apr 30, 2014 02:37 PM
    Make sure in the Captive Portal authentication profile that you do not have "Bypass Apple Captive Network Assistant" enabled.
  • 3.  RE: Apple iOS Wispr and Captive Portal
    Posted Apr 30, 2014 05:00 PM
    Below is our existing captive portal profile. Are you saying to remove the command "apple-cna-bypass"?
    aaa authentication captive-portal "ABC-Guest"
       default-role "DNR-Guest-auth"
       default-guest-role "ABC-Guest-auth"
       server-group "Clearpass-group"
       redirect-pause 1
       no logout-popup-window
       protocol-http
       login-page "http://1.2.3.4/guest/guest-registration-page.php"
       no enable-welcome-page
       apple-cna-bypass
  • 4.  RE: Apple iOS Wispr and Captive Portal
    Posted Apr 30, 2014 05:11 PM
    Yes
